Login Error
Close
7 Benefits of a 30 Year Home Equity Loan
by DoItYourself Staff
There are several benefits of having a 30 year home equity loan. This type of loan is generally the longest-term home equity loan. Many homeowners who apply for this type of loan are able to get their cash quickly and effortlessly. A home equity loan uses the equity in the home as collateral.
1. Low Fixed Rates
One of the benefits of obtaining a 30-year home equity loan, is that they usually come with lower fixed-interest rates than a regular 30-year mortgage loan. This can mean savings of thousands of dollars over the life of the loan.
2. Low Monthly Payments
Since this type of loan usually has a lower fixed rate, you can expect to have lower monthly payments. You have the knowledge that the monthly payments on a 30-year home equity loan will not change, like they would with a variable interest rate loan. This makes it easy to budget your finances accordingly.
3. A Loan Higher than your Home Value
With a 30-year home equity loan, you can often borrow more than the current market value of your home. Depending on the lender, you may be able to borrow up to 125 percent of the market value of your home. However, it is important to remember that the bigger the loan, the higher the fixed-rate interest may be, and the monthly payments will also be higher. It is usually advisable not to go over the actual equity value in your home. Real estate values fluctuate, and it isn't always a certainty that home prices will increase. When the time comes to sell your house, you may have a hard time selling.
4. Easy Application
The 30-year home equity loan is probably one of the easiest loan applications out there. Since it does not require many of the other documents, certifications and records that usually apply, the entire loan application process is essentially a breeze. It is quite easy and straightforward. This is because you are using the house as the collateral for your home equity loan. Usually an assessment of your property's value is the biggest determining factor.
5. Tax Deductible
A 30-year home equity loan can be a tax write-off. A percentage of the interest in a home equity loan can often be written off on federal income taxes, depending on how the funds from the loan are used, and only if the loan is on your principal place of residence. One should consult a tax advisor for the requirements and details, and to determine if you are eligible for the tax deduction.
6. Flexibility on Cash
A clear advantage of getting a 30-year home equity loan is that you are not restricted on how to spend the money you get from the loan. With some other kinds of loans, there are certain restrictions as to how or where you can spend the money. With this type of loan, you can spend the money however you want, whether for a dream vacation, college expenses or medical bills. How you spend the 30-year home equity loan money is completely up to you.
 forum activity
