7 Benefits Of Cabinet Refacing
Cabinet refacing is the process of replacing cabinet doors, drawer fronts and knobs and then applying new veneer to all the externally visible parts. Instead of breaking down the entire cabinet and installing a new one, you can reface your cabinets in the kitchen or bathroom. This process saves a lot of money, labor and time. Cabinet refacing is highly popular because of the remarkable benefits it offers.
Very Economical
On average, cabinet refacing costs about 50% or less than the amount of money you would spend on new cabinets. Whether you use this option for your kitchen, bathroom or elsewhere in your home, you can save a lot of money. In most cases, cabinets that look drab and dull are in perfectly good condition. If you are happy with the present layout of the cabinet and only want to give it a face-lift, cabinet refacing offers the perfect solution. A lot of money is wasted when good cabinets are ripped out to install new ones in a similar layout.
Less Complicated
Cabinet replacement is a huge task that takes days to complete. You will have to make changes to your schedule and plan extensively before you perform cabinet replacement. On the other hand, cabinet refacing can be completed in as little as a day or 2, with the correct personnel performing the task.
Prevents Wastage
If your cabinets are in otherwise good condition, there is no need to remove them. They will most probably end up in landfills and contribute to the accumulation of hazardous waste. In addition, you have to spend more money on brand new cabinets.
Offers Several Possibilities
With cabinet refacing, you have several options available to you. Some companies do a refinishing job on the exterior of cabinets and drawers, without removing the doors or the fronts of drawers. In such cases, you can have new veneer applied on the exterior and have new knobs and pulls installed. Your cabinet will still end up looking new.
Several Finishing Options Available
You can choose among a variety of veneering options and colors to reface your cabinets. Real wood veneers such as hickory, maple and birch are available. You can change the look and grain of the wood by choosing appropriate covers and doors. You can add new trim and molding as well. You have the option of adding glass doors to showcase collectibles.
Provides an Eco-friendly Option
Most cabinets contain a material called formaldehyde, which is a hazardous item if it ends up in landfills. You can prevent this by choosing cabinet refacing over new cabinets. Many companies that offer cabinet refacing also recycle the removed parts such as cabinet doors, hinges and drawer covers. Also, you can prevent the demolition of more trees that will be required to build new cabinets. Cabinet refacing is therefore a green option.
Provides a Brand New Look
The final results of a cabinet refacing are similar to that of cabinet replacement. There is no reason you should not choose this option if your cabinets are not in bad shape. You can save money, time and also the environment.
