Login Error
Close
7 Benefits to Canopy Lighting
by DoItYourself Staff
Canopy lighting can make a striking difference in your outdoor living space. You may want to install them along exterior sidewalks, entryways, patios, garages and under ceilings and canopies. Once installed, canopy lights don’t require maintenance for several years—an advantage that makes them hugely popular amongst homeowners. Read on to learn about several other benefits of canopy lighting.
1.  Increased Visibility
Canopy lights allow you to maximize your time outside. Your outdoor activities and recreation needn’t be limited by time and the cover of darkness. The Light Emitting Diode (LED) aspect of canopy lights enables a wider outreach of brilliant light. This also enhances security in your home as burglars tend to be discouraged by well lit areas.
2.  Increases Aesthetic Appeal
You can create a spectacular lighting display outside your house with canopy lights, giving your home a higher aesthetic appeal. The lights are available in numerous colors and styles. The wide range of lights is helpful for decorative purposes. Lighting displays can be extremely welcome during certain occasions and festivities.
3.  Energy Efficient
Canopy lights generally make use of the LED technology. This enables an extremely economical rate of energy utilization. Most exterior lighting utilizes up to 80 percent less energy. The lights also have a low heat output which contributes further to energy savings. It is possible to have the lights dimmed yet still remain efficient in the light they emit.
4.  Low Maintenance
Many exterior lights provide illumination for at least 10 years before maintenance becomes necessary. The low maintenance requirements add to the durability of canopy lights. The lights are securely sealed which helps to keep out dirt and bugs. This keeps them clean for longer. To clean the lights, you simply wash them down with a garden hose.
5.  High Durability
Canopy lights are generally manufactured to last several years. They have an extremely long operational life, often up to 100,000 hours. This is partly because they are installed in hard-to-reach areas. Manufacturers recognize that once installed, it is convenient if you don’t have to access the lights regularly. The low maintenance requirements of the lights also add to their durability. Heavy duty, durable material such as cast aluminum may be used for the housing. The lights have a characteristic rugged structure which gives them added resistance to shocks and vibrations.
6.  Environmentally Friendly
The low emission lighting associated with canopy lights helps to safeguard the environment. These lights do not contribute much toward global warming as incandescent lights do. Additionally, these lights aren’t associated with infrared dangers and ultra violet radiation. This further helps to safeguard the environment. The eco-friendly properties of the lights also help to safeguard your health.
7.  Cost-Effective
The low electricity usage and low energy output of canopy lights makes them a cost-effective choice. The low maintenance aspect of the lights further adds to their cost-effectiveness. Although the initial purchase price may be high, in the long run, canopy lights prove to be a cost-effective choice.
 forum activity
