cancel
Job type :
Zip Code :
community forums
comments
7 Deck Supplies To Keep Handy
If you have a wood deck, you will want to keep a set of deck supplies on hand to protect and maintain it. Wood is vulnerable to weather, termites, moisture, sun damage and general wear and tear. Regular maintenance will extend the life of your deck while keeping it looking beautiful.
Deck Supplies to Keep on Hand
  1. Deck Washing Solution—A deck washing solution can be applied every now and again as the deck needs it. The time frame is usually quarterly or every couple of months in areas that have extremely harsh weather. You just disperse the solution onto the deck and then rinse it off with a hose. For problem areas, you will need to scrub the area with a brush.
  2. Pressure Washer–A pressure washer is a great tool to have around because it facilitates a thorough cleaning of your deck. The condensed water that shoots out of the pressure washer lifts up dirt that may be compacted into the wood. This is an especially handy tool when the deck has not been cleaned in some time.
  3. Scrub Brush—A scrub brush will be needed any time you have areas of concentrated mildew or other contaminants and for removing bird droppings and other elements. A scrub brush is the next best thing to pressure cleaning.
  4. Outdoor Broom—Sweep off water and debris on a regular basis.
  5. Deck Stripper- This product removes latex paint and oil-based products that come in contact with your deck's surface.
  6. Deck Sealer—Decks should be sealed every so often, depending condition the deck is in. Between major applications, problem areas might additional sealant.
  7. Garden Pump—A pump will help ensure that the cleaner is applied evenly.
Basic maintenance for your deck is as simple as hosing it down every other day. Any kind of buildup can be harmful, causing wood to rot and decay. It is also unsightly and can make staining a considerably more difficult task than it should be. Keeping basic deck supplies on hand will encourage you to keep your deck in tip-top shape by maintaining on a regular basis.
member comments
Did-it-myself Projects
updated by dhammon
did this on 11/04/2009
The Deck
updated by dannyboy00
did this on 10/17/2009
Custom Front Porch
updated by mrbusdriverla
did this on 8/30/2009
My Relaxing Time...
How to Build a Shoe Storage Bench
sponsored articles of the day
