Login Error
Close
7 Essential Tools Need Dry Brush Painting Explained
by DoItYourself Staff
The dry brush painting method is a very unique practice that requires some skill and patience in order to get it just right. This method can be used in many different applications from watercolors, outdoor frescoes, and even creating a faux finish to an interior wall. Dry brush painting is gaining in popularity as many people are wanting to have a different look in their homes than the normal coating of gloss paint. The unique affects of dry brush painting can not be duplicated with any other method. If you are interested in trying out a little dry brushing, here are some of the essential tools needed to be successful at it.
Fine Point Brushes
When you are painting with the dry brush technique you are looking for a certain look. Straight lines, hard angles and other distinct geometric lines and shapes are not going to be present. A fine point brush will allow you to move the paint anywhere you want without the hassle of being too large or cumbersome. Dry brush painting needs to have a certain level of control in order to produce the faux patterns.
Lily Bristled Brushes
These are unique to faux painting, and dry brush painting in particular. They have a natural curve to them and contain a "V" shaped notch at the tip of the brush. Being naturally resistant to fraying is another great quality which gives you control when there is not as much paint on the brush as you are use to. These bristles will help you be able to blend in the colors instead of making a hard transition between colors.
Block Brushes
With dry brushing you are going to use very little paint on your brush. This means that the paint you do apply to the surface is going to need to be moved and pushed around. Block brushes have a wide stance to them so you can easily brush the paint without having any brush strokes left behind.
Comb
When you have some wet glaze on your wall that you want to mix in with the bottom paint color. A comb is essential to this process. These combs are available with either metal or rubber teeth which are in many different sizes and thicknesses.
Rags
Good cotton rags are also necessary for your dry brush technique. These rags are not for using to clean up any messes, but to provide another way to move the paint around on the wall. The rags are used to smooth out the lines and give a shading affect to the painting.
Pouncer Brush
The pouncer brush is perfect for keeping your dry brushing going even in small, constrained areas like corners, nooks and along trim pieces.
Softening Brushes
When you are doing your dry brush painting you are creating an affect that will make people feel better about the room as a whole. A softening brush is used to create that illusion by being able to soften the paint and blend in the colors to create a seamless transition between the two. Typically you would use this brush without any paint on it and just smooth out the paint that is already there.
 forum activity
