7 Foxglove Care Tips
what you'll need
- Foxglove plants
- Compost
- Mulch
- Shovel and trowel
- Stakes or metal hangers
Foxglove is the towering giant in a flower bed, with some varieties growing up to 5 feet. They are a biennial plant, which means they bloom their second year with beautiful, bell-shaped flowers, and then die. They reseed easily, but if you want flowering plants every year, you will have to plant foxglove two years in a row. They bloom in a variety of colors, and each plant's offspring will produce multi-colored flowers. The first year, a foxglove will produce leaves, but no flowers.
The foxglove is best planted at the back of your flower bed, otherwise it will block out everything behind it. It can also be planted outside a flower bed and will thrive as long as the soil is rich, and well drained. It can be planted along walkways and around trees. One precaution is to keep them out of areas where children play, as they are highly poisonous.
Here are some tips for growing healthy foxglove plants.
Step 1: Buying the Plant
When you are shopping for a foxglove plant, look for plants that have many, healthy looking leaves. Make sure you buy one that is already a year old so that you will have blooms that year. Avoid containers with multiple seedlings as these will need two seasons to bloom.
Step 2: Choose a Spot
The foxglove likes full sun, but in warmer climates, it should get shade in the afternoon. Generally, the foxglove prefers cooler climates, like zones 4 to 8. If you are planting it outside of a prepared bed, look for a spot that has rich soil with good drainage. It should be planted while temperatures are still slightly cool.
Step 3: Prepare the Soil
Foxglove prefers a rich soil, but can be planted in less rich soil as long as you add compost and mulch the area well. If the soil has poor drainage, you may need to add amendments to improve it.
Step 4: Plant
Dig a hole for the foxglove and put a handful of compost into the hole. Add the plant to the hole and gently firm soil around it. Water the plant, then add a thin layer of mulch. Use mulch like lucerne straw. This will protect the plant from slugs and snails. The plant will need to be fertilized, usually in early spring.
Step 5: Support the Plant
Because of their height, foxgloves may tend to droop under their own weight. You can help support them by tying them to a stake or by straightening a clothes hanger, inserting the straight end into the ground, and wrapping the hook around the plant to hold it up straight.
Step 6: Keep it Blooming
When the flowers begin to fade, cut the spike from the foliage. This will encourage new shoots from the sides.
Step 7: Use the Seeds
When the plants die, lay the dead plant on the ground where you want more to grow. You can also manually remove the seeds and sprinkle them in the appropriate area.
