7 Kitchen Track Lighting Wiring Tips
Kitchen track lighting is the modern way to add extra illumination to your kitchen. In addition to your traditional lighting options, this lighting will put that extra focus where you want it, like over the breakfast bar or island counter. What makes track lighting so appealing is the fact you can customize it to fit your kitchen to get maximum lighting. The most common ways to design your kitchen track lighting system are straight line, U-shape, and L-shape. Track lighting can work for all homes-both old and new. Before you think of redesigning the light system in your kitchen, take a look at the top seven tips for wiring kitchen track lighting.
Tip 1 - Turn Off Electricity
Anytime you are about to install or fix electrical wiring, always shut off the power source located in the junction or electricity box.
Tip 2 - Pay Attention to the Design of Your Kitchen
Track lighting is all about customization, but you have to work within the perimeters of your kitchen. Unless you are remodeling your entire kitchen, you must decide the exact location you plan on installing the lights. Here are a few things to keep in mind while deciding the location. Kitchen track lighting can work almost anywhere except in rooms with low ceilings and don’t install the lights where there might be interference with doors and cabinets.
Tip 3 - Consider Under Cabinet Track Lighting
If your kitchen has low ceilings or minimal space, maybe you should consider installing track lighting under the cabinets. This method of track lighting will require a smaller light system and may offer less flexibility, but it can make a big impact.
Tip 4 - Get Dimmer Switches Installed
Dimming the lights not only allows for more customization, but it also saves electricity. Choose the right setting of lights you will need for whatever needs to be done.
Tip 5 - Angle the Lights Right
Track lighting is kind of like spot lighting. You want the light in the right area but you also don’t want it to shine directly down of people’s faces. First you need to figure out whether you are using the track lights as a form of general lighting (I.e. the entire room) or to spotlight an area (like a counter or wall). And remember that sometimes a little light it better than a lot, especially if you’re trying to highlight a specific area.
Tip 6 - Figure out Where the Power Supply Will Come from
You can choose where the lighting’s power supply comes from, either a nearby electrical outlet or junction box. Try to use whichever is closest to the kitchen.
Tip 7 - Consider a Track Suspension Kit
This is the ideal choice for those who live in buildings or houses with high ceilings. A track suspension kit will bring the lighting closer to the focal point or room. Choose the right suspension kit by making the exact measurements on how low you want the lighting to stay. You could also consider pendant linear track kits in which the lights are suspended and hand much like a pendant or chandelier.
