Login Error
Close
7 Small Bathroom Design Ideas
by DoItYourself Staff
If you aren't working with a lot of space, a small bathroom design can be done with simple ideas that won't break the bank. Because your bathroom is small doesn't mean that you don't need all the necessities a larger bathroom has. Here are a few ideas that can help you make your small bathroom appear larger than it is.
Add Shelving
Storage space becomes a big issue in a small bathroom. Depending upon the type sink you have in your bathroom, like a pedestal, your storage space is extremely limited. Adding shelving to one of your walls is advantageous. You will be able to store towels on the shelves which will enable you to add more color to brighten up your space.
Consider the Wall Color
If the walls of your bathroom are painted with a dark color such as maroon, you should consider choosing a lighter color to give the appearance of a larger space. Dark colors creates the feeling of the walls closing in. Lighter colors give the space a feeling of openness. Off white paint is an ideal choice for a smaller bathroom.
Light Colored Flooring
Just as with the color of your walls, the color of your flooring also plays a significant role in the appearance of space. A light colored tile will also give your bathroom a wide open feel. Choose from colors like light blue, tan or gray to accent your bathroom. Incorporating these colors in conjunction with your walls will take care of the closed in feeling.
Pedestal Sinks
If you have a large counter-top sink in your bathroom and storage space is not an issue, replacing the sink with a pedestal sink will be ideal to create more space in your bathroom. Because of the availability of finishes and designs of pedestal sinks, finding one to match your bathroom decor will be easy.
Reduce Clutter
Sometimes a bathroom appears smaller than it actually is because of the amount of items that are present. Removing items that can be placed elsewhere will open up more space in your bathroom. Hampers, excessive storage shelves, and some items that are used for decoration can be removed.
Consider Adding More Lighting
Your bathroom's lighting, electrical and natural, have a lot to do with the overall small feeling of the bathroom. If you have just one fixture above your sink, replacing the fixture with a fixture that has multiple light bulb sockets will help with your electrical lighting. For natural lighting, allowing more light in by using lighter colored curtains will help brighten the space up as well. If your bathroom has no window, consider installing a skylight.
Mirrors
Mirrors in your bathroom are a great visual trick to make the space appear larger. Having more than one mirror, especially if they are facing each other, will reflect the light in the bathroom giving it a larger appearance.
 forum activity
