7 Tips for Installing Exterior Window Trim on Stucco
Exterior window trim is a great way to finish any property. This will hide the join between your windows and the walls of your house. Trim is also available in a variety of different finishes. If you have stucco walls then installing trim might seem difficult. With the right tools and materials there shouldn't be any problem for anyone to install trim on these houses. While house trim is normally used with houses which have siding, it can also be used on houses finished in stucco. There are some tips which make fitting exterior window trim on stucco even easier and simpler.
1. Measurements
The most important tip is to make sure that the measurements are completely accurate. The width and height need to be measured. The measurements need to be accurate so it's a good idea to write down the measurements so that you don't forget them.
2. Alignment
The trim needs to be installed so that it's centered against the window. Mark the middle on the frame and the sill so that the window trim is fixed accurately. When you're ready to fit the trim it's simply a matter of lining the marks up.
3. Applying Adhesive
The adhesive needs to be applied to both the window trim and the window sill, this will minimize the chances of air bubbles interfering and affecting the glue. Then it's simply a matter of using the marks you made to align the trim on the window properly.
4. Holding Trim in Place
The trim can be held in place while the adhesive cures. This can be done using tape or screws if desired. You must give the adhesive around a day to dry properly before removing the tape or screws which are holding the trim in place. This would make it difficult to hold it for long enough until the glue holds firmly.
5. Angles
When working with the side sill trim, you will need to cut the top at a 45 degree angle. The bottom won't need to be cut. The top piece of sill trim needs to have both of the sides at 45 degree angles. Measure and mark the trim with a pencil before cutting. A miter saw or block can also be used to make the cutting even more accurate.
6. Sealing Joints
All joints should be sealed by using caulk. However make sure that you clean all of the excess caulk off to perfect the job. Caulking can be wiped away by using a towel if required. Sealing all of the joints will ensure that the joints are weatherproof.
7. Painting
The trim can be painted using masonry paint or brick paint which is available in a wide range of colors and finishes. Once the trim is painted it needs to be left to dry. Then it only requires minimal maintenance work to keep it looking it's absolute best.
Installing stucco window trim is very easy and it's something that's very easy. It's also a great way to instantly improve the look of your home.
