Login Error
Close
7 Tips on Building a Brick Charcoal Grill
by DoItYourself Staff
A brick charcoal grill will last for years. If you are contemplating building one in your own backyard, there are some tips that will help make the project go smoother.
1 - Level Ground
Be sure that the area will be level before you start building your brick grill. Using a shovel to level out the dirt and then using concrete will give you an area that will not shift much after it is built. Go down into the ground 4 to 6 inches. Once level, add cement and level. If you do not lay down a foundation for your brick grill, it may become unsettled later from water, heat and cold. This can cause your bricks to crack making it unstable.
2 - Fire Resistant Mortar
When choosing the mortar for your project, you will want to choose a fire resistant mortar. This type of mortar is best used because you will be dealing with high temperatures with charcoal and you will not want to take any chances of fire getting out of control.
3 - Choosing the Grill Insert
When choosing the grill to insert into your new brick charcoal grill, opt for one that is ceramic coated, if your budget allows. They are a more expensive, but they will not rust. If you do not purchase a ceramic coated grill, you may have to replace the grill in a year or so because it is exposed to the elements.
4 - Check the Levels Often
As you are constructing the bricks into the form you want, use a level to be sure all sides are plumb. Having a side that is lower or higher than the others will cause your project to not only look odd, but it can cause damage later from the pressure, or tilt. Check to be sure all side are level as you add each additional row of brick.
5 - Leave Space for Air
When you adding bricks to the area where the grill will be placed, add 2 to 4 inches under where the grill pan area will be to allow air flow. This is very important for charcoal grills. The charcoal will not stay lit for long if it is unable to have air flowing around it.
6 - Be Creative and Choose the Right Bricks
You can find bricks in an array of color choices, sizes and designs. The most important element to your bricks will be to purchase good quality bricks. Some locations sell brick made especially for this type of project. Consult your local brick company for more information on what is available in your area.
7 - After the Charcoal Grill is Finished
Although you will be ready to fire up your new grill to try it out as soon as it is built, you will actually need to wait for 7 to 10 days for it to cure before using. The mortar will need time to harden. After your grill has cured, you will only need to clean it out regularly so you have a great barbecue every time.
 forum activity
