Login Error
Close
7 Trenchless Sewer Line Replacement Tips
by DoItYourself Staff
One of the new ways to replace a damaged drain system is to use a trenchless sewer line. This system is done without having to dig up any lines and causing damage to your landscape. This trenchless sewer line is a great investment and is easily installed by a professional or do it yourself homeowner. There are some tips to keep in mind when replacing a drain line with a trenchless sewer line.
Tip 1- Find Out Local Codes
Before you do any work to the sewage system you should always check with the local code enforcement office. There are plenty of changes in the building codes that may relate to your sewage system. It is important to make sure that your system is up to code and does not need any major alterations.
Tip 2- Check for Obstructions
Before doing any trenchless pipe repair make sure that there are no obstructions hidden under the ground. Most of the time you do not contact with any underground pipes or wiring. However, it is safer to check before doing any work under the surface.
Tip 3- Make Sure There Are No Large Breaks
If you have a wet spot on your lawn that means that there is leak in your drain lines. Depending on the severity of the leak the trenchless sewer line will not be able to coat the interior of the line. You must dig up the section of line to check on how bad the break is. If it needs to be replaced, you will need to do this before you apply the trenchless sewer line application.
Tip 4- Get Rid of Tree Roots
One of the most common problems found in drain systems is roots that have penetrated into the line itself. Even with a trenchless sewer line installed, the roots can break through the lining. You may not be able to cut down the tree if it in on the neighbor's land, but you can do something about the intruding roots. Before doing any work on the sewer line dig up any tree roots that are close to your line.
Tip 5- Unclog Any Drains
Before the trenchless sewer line can be installed it is important to keep the drains free of any clogs. Pour some drain cleaner or some septic tank cleaner down the drains a few weeks before using the trenchless sewer line. This will make sure that there are not clogs and the pipes are clean.
Tip 6- Dig Two Holes
In order to replace any drain pipes that may have a small hole in them you can easily repair this without having to damage the landscape too much. Dig two small holes at either end of the rupture and use the trenchless system. Slide the inflatable tube through one hole. You can manage the way it feeds through the pipe from the other hole.
Tip 7- Use Relining Instead of Replacement
The trenchless sewer line can either replace a section or coat the entire system. Use a lining replacement in order to protect the entire system against a weakened pipe, waste build up, or small cracks. This system is installed through the main drain pipe and uses a strong lining that seals any cracks and small ruptures.
 forum activity
