7 Types of Rain Gutters 7 Types of Rain Gutters
Surprisingly there are quite a few options to pick from when choosing rain gutters for your house, whether you are building your house or replacing existing gutters. Some things to consider are picking the color to match the roofing and trim of your house, the gutter size, and the coating to go over it.
Another thing to decide is what you want your gutters to be made of. You can pick from copper, steel, aluminum and zinc. If you opt for copper and zinc, they will cost you quite a bit more but will not have to be painted. The natural color the copper and zinc turn a natural brown color that will add to the beauty of your house.
1. Steel Style
Steel is stronger than aluminum and is a better choice if you live in an area with extreme weather climates. It can easily withstand expansion and contraction that comes along with the weather changes. They will hold up well but can be a little costly.
2. Aluminum Style
Aluminum is the least expensive option. It is light and easy to install and can be painted almost any color you want. It is one of the most common types due to the small cost and ease of buying.
3. K-Style
The K-style gutter is the most popular. It is so called because when you look at it from the side, it is in the shape of a K. If you look at it from the front, it looks like crown molding. The K-style gutter is formed by using a roll-forming machine. Most installers buy these machines since the K-style is the most popular. This also makes them the most affordable and easy to get.
4. Fascia Style
The fascia style is pretty plain. It is similar to the K-style only minus the crown molding look. It is more or less round and used where crown molding style may not look right with the house style. One benefit to the fascia style is that since it is smooth, it can hold more water and can be made thinner. This enables you to install these gutters and have them not be noticeable.
5. Seamless Style
The installer will bring a big rolling machine and form the gutter in one piece right at your house. This makes the seamless style quick and easy to install. There are no seams to try to match up and is just as functional as the other styles. Keep in mind, there will be seams when the gutter needs to turn a corner or have a downspout added or to have the end capped.
6. Wood Style
These are the most expensive type of gutters. They can outlast most types of material if they are cared for properly. Generally the wood gutters are used in restorations of older homes or in building custom buildings. If you go with wood, redwood and fir are your best bets as they are the most durable.
7. Vinyl Style
These gutters are generally used in areas of mild climates where there is not a lot of freezing and thawing. They cannot withstand a lot of weight, but do not show the wear from salt air. People living by the ocean or in trailers use this lightweight style as they are inexpensive and easy to maintain.
