7 Uses of a Bench Vise 7 Uses of a Bench Vise
While a bench vise is a versatile tool, it is not immediately obvious just how many different types of applications it can have. Whether you are working with wood, metal or other materials, this tool will provide the stability you need to perform with precision. What follows should give you a good idea of many of the things a vise can be used for, but it is by no means a complete list.
Using Glue
A vise can be incredibly helpful if you are using glue in a woodworking project. Instead of relying on gravity to hold your project together while your glue dries, you can put it in a vise, place it carefully, and leave it alone, knowing that your project will  remain perfectly in place until the glue is completely dry. For any project that involves precise measurement and gluing in order for all of the parts to fit together properly, this is a big advantage.
Metalworking
In addition to woodworking, bench vises also have many uses in metalworking as well. Bench vises can be used to hold metal in place to be cut or modified.
Using a Saw
Bench vises are also extremely useful when using a saw to cut lumber for your woodworking projects. Using a vise is by far the most reliable way to hold a piece of stock in place while cutting it. If you have ever had trouble using a saw freehand and wished that you had a way to better hold your lumber in place, a bench vise will provide the solution that you need.
Working with a Drill
If you are planning a project involving the use of a drill, you will definitely benefit from access to a bench vise. A vise is absolutely vital when performing a task like drilling that requires serious precision and stability. Using a bench vise will allow you to drill holes with more accuracy than you would be able to get without using one.
Using Sandpaper
Finishing a project with sandpaper will take a lot of time, no matter what conditions you do it under. However, with the proper planning and tools, you can minimize your work and maximize your effectiveness while sanding. A bench vise is a significant part of doing this. By having your project secured thoroughly without the use of your hands, you can make sure to not accidentally damage it, or spend more time struggling to get it in the right position than you do actually working on it.
Cutting Conduit
When cutting electrical conduit, it is important to secure the conduit in place firmly with a vise before cutting it. A bench vise is a perfect way to do this.
As a Work Bench
It is important to remember that anything a regular work bench can do, a bench vise can do just as well. If you are going to give up enough space to fit a bench vise, there is no reason not to maximize the amount of use you get out of it.
