Login Error
Close
8 Advantages of Using a Punch Down Tool for Your Electrical Project
by DoItYourself Staff
A punch down tool is a hand tool that is used in electrical projects, particularly in projects that involve telecommunications and networks. The tool can be used to terminate cross-connect jumpers and cable runs at patch panels, 66 blocks, and 110 blocks. This simple tool can easily cut through wires effectively and speedily. To use the tool, the wires of a cable are inserted into the punch down block and set into place. The push down tool is simply pressed down on top of the wires. The tool cuts the excess wires and attaches the wires to the block. Below are some of the advantages of a punch down tool.
Easy to Use
The punch down tool, or the krone tool, is very simple to use. It also has a handle that allows easy and firm gripping. Once the wires are stripped off from their protective casing and placed on patch panels or push down blocks, the tool can be easily positioned on top of the wires and pushed to set the wires in place. Afterward, it cuts off the excess wires.
Sharp Blades
The blades on the tool can cut wires cleanly and speedily. Every push down tool is manufactured using quality metal blades that can cut through wires effectively. Unlike other cutting tools, this tool is designed to have blades that are interchangeable to suit every type of wire. The blades are made of hardened steel and are designed to be sharp to offer reliable and quick operations.
Time-saving
Connecting cables to patch panels, push down blocks, or jacks may prove to be time consuming when using other types of cutting materials such as knives, cutters, or scissors. With a push down tool, the job can be done in a single and speedy operation.
Precision
The handy tool also cuts with precision and uniformity. As the tool is pressed down on the wire, the blades cut off the excess wires precisely. This provides a professional look on the finished project.
Impact Mechanism
Most push down tools work with an impact mechanism. The impact mechanism helps provide an efficient and uniform cut that will produce an evenly made connection. As soon as the push down tool is pushed, the impact mechanism is triggered to allow you to work with less effort.
Adjustable
Push down tools are designed to have adjustable blades and impact mechanism to fit any type of wire and thickness. The tool’s impact strength can be adjusted in order to produce an effortless cut.
Color-coded
One side of the tool has a cutting blade. To avoid cutting the wrong side of the wire, the tool is color-coded to show a user which side has the blade. Cutting the wrong side of the wire will definitely be a waste of time.
Corrosion Resistant Connection
With the precision and sharpness of the blades, connections are made to be secure and resistant to corrosion. This provides connections that can withstand the test of time.
 forum activity
