8 Easy Tips for Bathroom Maintenance 8 Easy Tips for Bathroom Maintenance
Regular bathroom maintenance is an essential part of housekeeping. It will save you a considerable amount of money over the long run because you can avoid problems related to plumbing, leaks, mold, and mildew. Some easy tips for regular bathroom maintenance are listed below.
Ensure That the Grout and Sealant Are Intact
The grout and sealant around the tiles over a bathtub or in a shower cubicle require frequent inspection. Due to the constant exposure to heat and moisture, the grout often wears or cracks. Ensure that the grout is intact and free of mold or mildew. To clean mold, mildew, or grout stains, use oxygen bleach. If you find any evidence of missing grout, you must clean the area, dry it, and apply new grout.
Look for Leaking Spouts or Pipes
Leaks around a pipe or spout must be remedied as soon as they are detected. If left unattended, they could progressively become worse and cause problems such as moisture accumulation behind the walls and underneath the floor. Contact a plumber if you are unsure of the extent of the leak.
Look for Signs of Leaks Around the Bathtub and Toilet
The toilet and the bathtub must be securely caulked to the bathroom floor; otherwise, these fixtures will leak. Ensure that the toilet flush works properly and that there are no blockages.
Look for Signs of Rot or Decay
Do a regular examination of the floor, wall, and corners of the bathroom. Look for signs of dampness, wetness, and rot on the surfaces. Any such problems must be remedied professionally.
Check for Loose Tiles
If you have a shower enclosure, ensure that the tiles are in place and caulked properly. Also ensure that there are no signs of shifting tiles on the wall or floor. If you see any such signs, remove the tiles and install new ones or reinstall the same tiles. Reapply the grout after removing the debris between the tiles.
Inspect Under the Sink
Look under the sink for leaks and moisture accumulation. Corroded pipes or cracks in the connections cause leaks that can spread to the wood under the counter. It can also damage the foundation. Replace any damaged pipes or connections promptly.
Use Drain Covers
Drain covers are an important defense mechanism because they block the flow of hair, dirt, and other particles that can clog the drains. If you notice that the flow of water has slowed, clean the drain and the covering grill.
Clean the Bathroom Weekly
Clean the bathroom at least once a week. Clean the bathtub, shower enclosure, toilet, wash basin, mirrors, and the floor. While doing so, perform a thorough inspection of all the nooks and crannies. Wash the rugs before they accumulate too much dirt or moisture. Never leave moist clothes or rugs in the bathroom.
