Login Error
Close
8 Easy Ways to Organize Basement Storage
by DoItYourself Staff
Although the basement storage area of the house is not a frequently visited area, it is important to keep this organized. An organized basement area will make area available in the basement that can be used as a gym or a study room, which adds to the property value of a house. Keeping the basement clean and organized helps prevent moisture and mildew from gathering.
Make use of the following tips to organize the basement storage in a better way.
Don't Toss Items: Avoid the habit of tossing items in the basement without any thought as to where they should be placed. The basement should be organized so that eatable items, mementos and documents have their own demarcated space.
Sort items: Sort through the items in your basement storage area. Establish a ground rule where an item that has not been used for six months should be discarded or given away. Regular spring cleaning should be adopted as a habit. This will keep your basement storage neat and clean.
Install Shelves: Install shelves or cabinets to store items of everyday use like canned foods, toilet rolls and paper towels. You should install the shelves in a vertical direction rather than horizontal direction as there is much more space available in the upward direction. Tall shelves will help increase the amount of items that can be stored.
Use Plastic Bins: Place food articles in waterproof plastic bins. Use silicone gel to avoid moisture from spoiling the eatables.
Use Clear Plastic Storage Bins: Use clear plastic storage bins for items where you need to tell at a glance what items are stored in them. You can also label the boxes to indicate what is stored inside them.
Install Hooks: Do not use the basement pipes to hang any items. Install hooks on the ceiling or within cupboards from which items can be hung.
Have Space: Ensure that there is enough space to move around the utilities that are installed in the basement storage area. These would include the washing machine, water heater and electric fuse box.
Keep Toxic Elements Away: Keep toxic elements away from the reach of children by placing them at a height.
 forum activity
