8 Faux Paint Granite Tips and Techniques Explained
If you want to renovate your kitchen countertops on a budget, consider faux paint granite. You can achieve the look of real granite for as little as $50. Faux granite is growing in popularity as more homeowners recognize the ease and simplicity of use of the product. To achieve the most realistic looking finish, you must follow the tips and techniques listed below.
Tip 1 – Prepare the Surface Beforehand
Faux paint granite is a good choice for several surfaces including countertops and tables. Before you start painting the surface, you must ensure that it is thoroughly clean and will provide good adhesion for the paint. A greasy or dirty base surface will result in a blotchy, uneven finish. Thoroughly clean the base surface and sand it. Clean off all the residue and dust. Wipe the surface clean with a damp cloth. Let the surface dry properly before applying the base paint.
Tip 2 – Print Out Pictures of Real Granite Surfaces
To get a clear idea of how you want your countertop to look, it is helpful to refer to several pictures of granite surface. You can find many on the internet. Keep in mind the surrounding décor and suitability of the colors before you decide on the primary and secondary colors. Most faux granite surfaces consist of a single base or primary color and 2 secondary colors.
Tip 3 – Protect the Surrounding Area and Floors
A faux paint granite project can get very messy. Most of the time, high gloss oil paints are required, which are difficult to clean out. It is therefore important to protect the surrounding areas with rag cloths or newspaper. Cover the immediately adjacent surfaces with masking tape.
Tip 4 – Work in a Well Ventilated Area
To avoid fume inhalation, you must work in a well ventilated area. Keep windows open and wear gloves, old clothes and a face mask. Keep children and pets away while you work on the project.
Tip 5 – Apply Primer First
A primer provides a good base area for the paint to adhere. Once you apply the primer, let it dry and then apply a second coat. This usually serves as the base color as well. Most often, white, black or gray are used as the base color.
Tip 6 – Apply Subsequent Coats
After you apply the second coat of primary paint, use a natural sea sponge to apply the first secondary color in uneven blotches. This will make it look more natural. Follow up with the second color on top.
Tip 7 – Apply Small Amounts of Secondary Color at a Time
When you apply the secondary colors, you must be careful to apply small amounts at a time so that you do not end up covering the primary base color. If needed, you can always apply additional blotches of paint on top to achieve the perfect look.
Tip 8 – Thoroughly Seal the Surface
A high gloss polyurethane sealant is vital, because it provides protection and the high gloss most of us associate with granite. Apply 2 or 3 coats of the sealant, allowing each one to dry before the next coat. Let the faux paint granite surface dry for a couple of days before using it.
