Login Error
Close
8 Oil Furnace Safety Tips to Consider
by DoItYourself Staff
An oil furnace is a cost-effective, efficient appliance. Oil furnaces are renowned for their superior safety and other attributes such as low operating temperature and uniform heating capabilities. During the operation of an oil furnace, there are a few safety precautions you must follow. Doing so will greatly reduce the risks of accidental fires or injuries.
1 – Ensure Efficient Functioning of the Furnace
An oil furnace burns oil to produce heat. For efficient functioning of the furnace, the oil must be burned completely, with no remnants left over. If the oil is not being burned completely, you will most probably find black smoke emitting from the chimney, an accumulation of soot or other such problems. If any of these signs become apparent, it is clear that your oil furnace is not working properly. Contact a service professional for advice and sort out the issue.
2 – Clean the Filter and Pump Strainer Regularly
Oil furnaces have strainers and oil filters that keep out dirt and debris. By doing so, they ensure smooth, efficient working of the furnace. Clean the furnace filter and pump strainer once a month or so. Doing this will keep the oil flowing smoothly and avoid blockages.
3 – Keep Stack Control Clean
The stack control is a safety device that shuts off a malfunctioning oil furnace. Keep this part of the furnace clean and well-maintained, so that you can avoid problems. Regularly clear out dirt, debris and grease from the stack control. If the furnace shuts off, try cleaning the stack control and then reset the furnace. If these steps do not succeed, you must contact a service professional.
4 – Clean Blower and Thermostat Regularly
The air blower and thermostat must be kept clean to ensure safe operation of the furnace. A clogged or dirty oil furnace can lead to accidents.
5 – Avoid Keeping Combustibles Close
Never leave combustible materials or inflammable liquids in the close vicinity of your oil furnace. Though these appliances operate at lower temperatures, there is always a danger of fire if inflammable articles are kept nearby.
6 – Avoid Replacing or Repairing Parts Yourself
An oil furnace consists of many small parts and pieces that form the whole. In some cases, a problem with the furnace may be hard to detect or point to a single source. If you are unsure of how to proceed, avoid experimenting with your oil furnace. This could lead to serious accidents and also void your warranty.
7 – Avoid Blocking Registers
Ensure that the registers on your oil furnace are free of blocks such as cloth or draperies. Proper clearance is important to the safe operation of your oil furnace.
8 – Contact a Professional if Furnace Does Not Light Up
If your oil furnace does not light up, follow the instructions mentioned in your owner’s manual. Ensure that the fuel tank is not empty. Refill it if necessary and clean out the filter, air blower, control stack and pump strainer. Ensure that the belts are clean and intact. Also check the thermostat level. Beyond these steps, never try to replace or repair parts of the oil furnace yourself.
 forum activity
