8 Signs of a Bad Diesel Fuel Pump
If a car has a diesel fuel pump, you must keep it in good working condition. If you are having any difficulties with bad diesel, this means that there is some problem with the diesel pump. Read on to learn about some of the symptoms of a bad diesel fuel pump that you must immediately remedy.
High Pitched Sound
When your vehicle starts making a high-pitched sound, it could be a sign of a bad diesel fuel pump. Different vehicle pump makes different sounds; there might be a scraping sounds or even a high-pitched noises. If you hear unusual noises of any kind, make sure to have them checked out.
Low Fuel Pressure
Low fuel is another indicator of a bad diesel fuel pump. Your vehicle might not work properly if there is no proper pressure. The low pressure of the fuel pump can not start the vehicle even though the switch is on and properly functioning. Thus, this low pressure can cause fuel pump to work in an improper way.
Problems Accelerating
If your vehicle suddenly has a trouble in accelerating, it might be a symptom that you need to replace your fuel pump. This usually happens when the pump is not supplying an adequate amount of fuel.
Gasoline
Always make sure that your car never runs out of gasoline. This will help in increasing the life of your fuel pump and will make it work in a proper way.
Malfunctioning Filter
Many times, the filter of your car might seem to work improperly. This meansthat you need to replace the filter on a daily basis, as they end up being worn out over a very short period of time.
Breakdown
Make sure that you try to avoid a total breakdown while driving your vehicle. This can cause in spoiling your diesel fuel pump.
Low Power
Sometimes, your vehicle might have a loss of power. It usually ends up slowing down the car. However, a loss of power should never be ignored. Thus, this is a good symptom as well, in order to find out if it is time to replace your diesel fuel pump or no.
Engine Stops
The engine might come to a halt any time for a moment or two. This may be because of continual fuel feed from the gas tank.
Replacing a bad diesel fuel pump can be expensive and time consuming. The elements of the diesel would be able to last for about thousand hours or maybe even more, depending on how you drive the vehicle. However, diesel fuel is very unstable, as the solids end up gathering up in the tank, which ends up leading to blockage of the diesel filters. This will end up ruining the vehicles injectors, and would cause the diesel engines to work in an improper way.
