Login Error
Close
8 Tips for Cleaning Aluminum Siding
by DoItYourself Staff
With the right materials and techniques, cleaning aluminum siding can be a very easy and effortless task. Aluminum siding is an attractive, resilient and tough material to use for the siding in your home. It requires very little maintenance, but that little maintenance should be maintained for the best look and lifespan for your siding. Following are some of the tips that can be useful in cleaning aluminum siding.
Clean Aluminum Siding Regularly
To prevent excessive dirt, dust and mold from accumulating on aluminum siding, it is recommended to maintain a regular cleaning schedule. Cleaning the siding at least once a year will keep it looking better and make it last longer.
 Be Prepared with the Required Cleaning Gear
You will need laundry detergent, bleach if there is mildew on the siding, water from a hose or pressure washer, a cleaning brush, gloves, protective eye wear, a hat and a jacket. You will need either a long handle on your brush or a ladder. Make sure you choose a pleasant day to work outdoors, as the task may take some time. If you choose to use a pressure washer, you must be very careful to use a low setting, to avoid damage to the siding or cause water to pass through to the underside.
Prepare the Cleaning Area
Before you clean the aluminum siding, you must clear the area of all items that may be damaged by the cleaning solution. Ensure that there is no way the water can enter your home through openings in windows or doors close by. Cover any outdoor plants with plastic to avoid damage. Ensure that there is no risk of electrical hazards, by turning off all electric equipment nearby.
Use Appropriate Materials to Clean Mildew and Chalking
To clean stubborn mildew, you will need bleach. To distinguish between mildew and dirt, apply a small amount of bleach on the area in question. If it remains dark in color, it is dirt. If it changes color and lightens, it is mildew. Vinegar and borax are other good, eco-friendly alternatives for cleaning mold and mildew. You can also look for special cleaning solutions that are meant for cleaning aluminum siding. You can find such solutions at a hardware store.
Rinse the Siding before and after Applying Cleaning Solution
By rinsing the siding beforehand, you can get a better result with the scrubbing and cleaning. You must also promptly rinse the siding after cleaning, before the solution dries out and leaves marks.
Work from the Top Down
Start scrubbing the siding from the top, using a soft brush that will not leave marks or scratches. Promptly rinse the areas that have been cleaned, and move downwards. This will avoid formation of drip marks on the siding.
Use Assistance if Needed
You will need some assistance if you are going to be working on a ladder. Have someone hold the ladder when you climb on it to scrub. Falls from a ladder can be very dangerous, and must be avoided at all costs.
Spray Water at an Angle
Avoid spraying water directly at windows and doors, as there is a chance it may leak in through small gaps.
 forum activity
