Login Error
Close
8 Tips for Making Your Home Studio Computer Run Faster
by DoItYourself Staff
Your home studio computer plays a vital role in the overall process of recording, saving and sharing music and video files. Whether you use a Windows PC or an Apple Mac, there may be times you find your computer is running slower than usual. There are several reasons behind a computer’s deteriorating performance. With a few easy tips and regular maintenance, you can keep your home studio computer working at the peak of its ability. Below are some of the tips you can use for making your home studio computer run faster.
1 – Use High Quality Software
Probably the first step to smooth computer performance is using the best software you can get. There are several versions of open version and professional recording software available today. Check out the features of each and choose the one that is most suited to your requirements. If you can afford it or if you can share the cost with your band members, you must opt for professional software.
2 – Stick to Tested Versions of Software
Software companies come out with new updates and versions all the time. Though it is tempting to always update your software, it is better to wait till the latest version passes the beta stage. Till then, it is better to stick to your stable version.
3 – Check for Viruses and Spyware Often
Viruses, spyware and Trojans can seriously degrade computer performance. Use a good antivirus program to eliminate all such problems. However, you must also ensure that the antivirus program does not take up a lot of memory and does not run in the background all the time.
4 – Add a Hard Drive and Extra Memory
Additional memory is one of the best ways of speeding up your computer. Add a hard drive and additional RAM for fast performance. An external hard drive is better, because you can save a copy of your work on it and take it with you.
5 – On a Mac, Disable Unused Widgets and Clear the Desktop
Widgets on MAC can use up a lot of memory. Look through the widgets and disable all those you do not need or use.
6 – Look for and Turn Off or Uninstall Unwanted Programs that Run in the Background
Check the Activity Monitor (Apple) or the Task Manager (Windows) often. This will give you an idea of the memory allocation on your computer. You may find many programs that run in the background and use up memory, thereby slowing down the system. You can disable or uninstall these programs to free up memory.
7 – Run the Disk Defragmenter in Windows Once a Month
Windows computers have the disk defragmenter option that lets you merge all the fragmented data on the disk. Once the data is merged in one location, computer performance speeds up significantly.
8 – Delete Unwanted Data Regularly
Every month or so, make it a habit to inspect your hard drives and delete files that you do not need anymore. In most cases you will find that you are keeping large files that you finished work on a long time ago.
 forum activity
