Login Error
Close
8 Tips for Removing Epoxy Adhesive
by DoItYourself Staff
Epoxy adhesive can be a versatile item in your toolbox. However, knowing how to use it properly is the key to preventing the adhesive from going where you don't want it. In the event that you accidentally put some epoxy adhesive on yourself or on something else, there are many ways you can remove this bonding material. You can choose from a simple home remedy technique to a powerful adhesive remover.
The removal of epoxy adhesive largely depends on what you use the epoxy for, but here are some tips you can follow.
Removing Epoxy Adhesive on Skin
Vinegar: You can find a simple solution in your kitchen to remove any residue on your tools. You can use vinegar to remove cured epoxy adhesive from brushes as well as your skin. With a cloth, soak the area on your skin with the vinegar until you can see that the epoxy adhesive begins to soften. Once it has softened, remove the adhesive. You can also use vinegar on uncured epoxy.
Acetone: Acetone is another simple yet effective solution. Just like vinegar, you can use acetone to remove residue on your skin. Although it has almost the same effect as vinegar, acetone is flammable and may cause more harm. If you do plan to use acetone, however, caution is advised. Work in a well-ventilated space away from any flammable objects.
Citrus-Based Waterless Hand Cleaner: If you can find one, a citrus-based waterless hand cleaner can also do the job of removing fresh epoxy on your skin. Just rub the hand cleaner on the affected area and wash it thoroughly.
Removing Uncured Epoxy Adhesive
Isopropyl alcohol: You can use isopropyl alcohol to remove any uncured epoxy adhesive. "Uncured" refers to the stage wherein the adhesive in the bonded materials are set aside to dry for 24 hours.
Since uncured adhesives are not yet fully cured or dried, you can also use acetone or alcohol to remove any uncured epoxy adhesives on a surface.
Removing Dried/Cured Epoxy Adhesive
Adhesive remover: Removing dried epoxy adhesive may require a lot more than your ordinary kitchen solutions. You can try using an adhesive remover. However, you shouldn't use these removers on the skin. Only use the adhesive remover on surfaces of certain materials like wood or plastic.
Paint thinner: You can also use a solution of paint thinner and denatured alcohol to remove any dried epoxy adhesive. It is important to remember that these solutions can be quite harmful, so exercise caution when you handle them.
Denatured alcohol: Soak a rag with denatured alcohol and wipe it on the affected area. Denatured alcohol is more suitable for recently dried epoxy resin. If the epoxy has started to cure, you need to use the paint thinner first to soften it up.
Heat gun: For tough residues, you can use a heat gun to soften the epoxy adhesive. It is ideal to heat the area up to 200 degrees. Only heat a small area at a time to avoid causing any flames or burning the material. You can then use a scraper to scrape off the epoxy adhesive.
 forum activity
