Login Error
Close
8 Tips for Using a Wireless Home Security System
by DoItYourself Staff
With the advent of the wireless home security systems, the days of wired security systems have come to an end. It is the least complicated security device that made the home security a lot easier. Its installation as well as its operation is relatively easier and faster. If you know better how your wireless alarm system works, there is no way a burglar can ever break into your home. Following are some useful tips to improve the usability of your wireless home security system:
1. Determine the Coverage Area
First of all determine the total number of doors and windows that should be covered under the range of the home security system. This will provide you a basic idea of the total area coverage. The calculated area will further determine the capacity of the home security system that needs to be purchased.
2. Select the Place for the Control Panel & the Keypad
You will have to select the most suitable place for the control panel, from where you can easily operate the security system. Remember, the place should be in an area where you can reach anytime whether it is day or night or is some emergency.
3. Gauge the Range
It is essential to install the security system and its components at the proper place to make every area in the house invulnerable to burglary. This will ensure that no area remains away from the wave range of the security system. This becomes all the more important in the case of motion detectors, which usually run on batteries.
4. Pet Friendly Alarm System
If you own a pet or two, it would be wise to have a pet friendly security system. Otherwise, your own security system would become a nuisance for you. An ordinary wireless security system will regularly ring the alarm taking your pet for an intruder.
5. A Complete One-In-All Alarm System
If you want, you can also integrate several other alarm systems in your wireless security system like, lamp sensors, motion sensors, glass break sensors, smoke detector, panic buttons, voice dialing, etc. Though, you will have to spend some more, you will get a complete one-in-all alarm system that will alert you in any eventuality.
6. Wireless Visuals or Wireless Audible
You can choose to install some cameras to visually monitor the areas of your house, with most vulnerability. Usually, a typical wireless home security system has the capacity to accommodate up to 16 cameras.  On the other hand, if you feel that the cameras are too intrusive, you can choose to install some microphones instead. These microphones will make the alarm ring, in case the noise level crosses a predetermined threshold.
7. Try the Silent Alarm System
If you don’t want the intruder to get away by hearing the alarm, you can install the silent alarm system. A silent alarm system will alert the local police but not the intruders.
8. Interference from Other Wireless Systems
Make sure that any other wireless system in your house doesn’t interfere with the waves of the home security system. Sometimes, a wireless system of your neighbor can also interrupt with the working of your wireless home security system. So, you will have to choose a place for the installation of your security system, very cautiously.
The bottom line is to know your wireless home security system as closely as you can to get the most out of it, without losing your sleep.
 forum activity
