Login Error
Close
8 Wonderful Benefits From a Pool Water Ionizer
by DoItYourself Staff
A pool water ionizer is a device that releases positively charged silver and copper ions into the pool water. These ions kill the microscopic organisms such as algae, bacteria and fungi in the water. The use of a water ionizer also improves the pool water filtration. There are several benefits to using a pool water ionizer.
1 – Better Filtration
Most pools get dirty because of the presence of minuscule particles in the water. These particles are too tiny to be filtered out and remain in circulation in the pool water. The positive copper and silver ions emitted from the pool water ionizer bind with these particles, which are negatively charged. After the process of binding, the particles are large enough to be weeded out with the process of filtration.
2 – Kills Algae and Bacteria
The water pool ionizer emits a small current, which is highly effective in killing the micro-organisms in the pool water. This removes the presence of algae, bacteria, viruses and fungi in your pool, making it safer for you to enjoy.
3 – Minimizes Requirement for Chlorine
A pool water ionizer is effective in tackling algae and bacteria in most swimming pools. To improve sanitization, you may need to add small amounts of chlorine. You require minimal chlorine to be added to the pool, to improve the overall cleansing. In most cases, the chlorine required is so small in quantity that it cannot even be detected by swimmers.
4 – Keeps Pool Looking Great
With the use of a pool water ionizer, you can enjoy clean and clear water in your swimming pool. You do not have to worry about the odor of chlorine and other chemicals. Water stays clean for a longer time and maintenance is reduced.
5 – Better for the Pool Components
Over time, chlorine and other chemicals can react with the components in the pool, made of metal or otherwise. Corrosion and chemical reactions degrade the materials and reduce the lifespan of the components. With the use of a pool water ionizer, you can maintain your pool in great condition for a long time.
6 – Safe for the Skin and Eyes
Most swimmers complain of dry, itchy skin, rashes and burning sensation in the eyes after swimming. The culprit behind all these problems is chlorine, which is added generously to the water. When you use a pool ionizer, you require minimal chlorine, which makes it safer for people who are sensitive to it.
7 – Harmless to Humans and Pets
Water pool ionizers pass a mild current through the water, which is not tangible to humans and animals. Therefore, your pool is safe for everybody to use, with none of the side effects of chlorinated water.
8 – Saves Money in the Long Run
When you use a pool water ionizer, you do not have to spend money buying as much chlorine and other chemicals, which are harmful to your health and the environment. Over a long term, you save more money with the use of a good pool water ionizer that is appropriately sized for your pool and properly maintained.
 forum activity
