Login Error
Close
9 Energy Saving Tips For Kitchen Appliances
by DoItYourself Staff
Energy saving tips can help us reduce our energy consumption. This is especially true when it comes to kitchen appliances because the kitchen is the one room that consumes the most amount of energy. By keeping a few things in mind, it is possible for everyone to conserve more energy and also save a great deal of money.
Fix Air Leaks
Air tends to leak out from exhaust fans, even when they are not in use. To prevent this, be sure to install exhaust fans with covers. These covers attach to the fans with magnets and can be easily replaced.
Keep Appliances Clean
Keep all kitchen appliances in good working condition and clean them regularly. Smoke is often generated when appliances are not clean. Heating up an appliance, such as an oven, consumes more energy when it has a lot of mess stuck to it.
Kitchen appliances that are more than 18 years old consume more energy than newer ones. They should be replaced to reduce your energy bill.
Buy Energy-Saving Kitchen Appliances
Buy energy-saving options if they are available. For instance, electronic ignition systems are connected to ovens these days; this helps the ovens consume 30% less energy compared to the older models. The appliance may cost more upfront, but the energy savings can add up over time.
Turn off Appliances
Turn off the exhaust fans at least within 20 minutes after you are done working in the kitchen. If you need to replace your exhaust fans, buy the most energy efficient model. A good rule of thumb is: before going to bed each night, walk around and check if the plugs of all appliances have been pulled out of the sockets.
Stop the Dishwasher Drying Cycles
Dishwashers consume considerable amount of energy. If you do not need to immediately use the dishes, you can reduce energy costs by not using the drying cycle. You can take the dishes out of the dishwasher before the drying cycles and letting them air dry instead.
Use Smaller Appliances
Smaller appliances consume less amount of energy that that of the larger ones. For instance, if you can use a toaster, electric pan, or slow cooker to heat your food, then use it rather than an oven.
 “Stored” Heat
Heating and cooking appliances retain heat for some more time after they are switched off. After you are almost done cooking your food, switch off the electricity so that the appliance uses the energy that it has already stored in it.
Recycle Electrical Appliances
Nowadays, there are services available for recycling old electrical appliances. If you think that your old electrical kitchen appliances can be revived and reused, look up the number of the nearest recycling center and ask if they also recycle electrical appliances. You could also donate your old appliances to charity homes so that they find another good home to serve.
 forum activity
