Login Error
Close
9 Tips for Buying a Foreclosure
by DoItYourself Staff
In the world of real estate, a lot of opportunities can come your way and one such opportunity is buying a foreclosure that could earn you huge profits. However, buying foreclosed properties is not simple. You have to consider a lot of factors before you take the plunge. If you do not carefully study your intended purchase, you may lose more money than you have to gain. Below are some tips on what to do and consider when buying a foreclosure.
1. Stay Within Budget
Even though the prices are cheap, it doesn’t mean that you can just buy any property without working with a budget. Always set the maximum amount you can spend on the property. You still have to consider a lot of things such as repairs, transfer charges, etc.
2. Make a Visual Inspection
Don’t just settle for a description that’s written on paper. Also, do not trust verbal accounts of the property. You need to see for yourself, just in case there are hidden defects that the owner may be trying to pass on to you.
3. Check the Landscape
Check the condition of the landscape when you do your visual inspection. An untrimmed and wild landscape more or less means that the property has been neglected. If there are a lot of weeds that are untrimmed and wild plants growing everywhere, be wary of buying a foreclosure in this state.
4. Hire an Appraiser
If you are borrowing money from a bank, it will usually send in an appraiser in order to check the property and see what it’s worth. A high appraisal value usually means that the property is worth it and you should buy it, especially when you know how much a property actually costs.
5. Expecting Fast Profit
When buying a foreclosure, it is best to manage your own expectations and don’t anticipate large profits right away if you plan to resell. A lot of these properties usually get idle for a while until a buyer shows up again.
6. Winterized or Not?
When inspecting the house, make sure that it has been winterized. Make sure that before opening the heater or water, the integrity of the pipes has not been compromised due to the cold weather. If you turn on the water for example, leaking pipes that were not winterized could cause water to leak into the walls, which would mean additional repair.
7. Attend Sherriff’s Auction
These auctions usually produce the cheapest properties so buying a foreclosure from these auctions can be a great opportunity for you. However, due to these low rates, it is usually very difficult to get the winning bid since a lot of people have already thought of what you were thinking.
8. Bid Wars
When you are at auctions in buying a foreclosure, keeps your wits when bidding. Don’t get sucked into a bidding war with other interested buyers. You may spend much more than you originally intended to spend.
9. Compare Properties
Don’t buy the first good deal that you come across. Inspect other foreclosures first so you can have time to compare the rates of the different properties. This information gives you more leverage when you are trying to negotiate in buying a foreclosure.
 forum activity
