Login Error
Close
9 Tips for Cleaning a Hand Saw Blade
by DoItYourself Staff
Cleaning an old or used hand saw blade either for maintenance or restoration purposes is an easy task that you can complete in less than an hour. All you need are basic cleaning materials such as sandpaper, metal scraper, boiled linseed oil, paste wax and some used newspapers. Here are some tips on how to clean a hand saw blade.
1. Safety First
Always wear a good pair of working gloves and mask before cleaning a hand saw blade. In cleaning a hands saw blade you will need boiled linseed oil and mineral spirits which are irritating to the skin and to the lungs and mucus membranes.
2. Use Old Newspapers
Old newspapers are perfect for protecting your worktable and it also makes easy cleaning of the rust residue from your scraping and sanding. All you need to do after scraping and sanding is carefully fold the newspaper and throw it in a waste bin.
3. Use a blade Scraper
Use a blade scraper to remove surface rust. Hold the blade scraper at low angles and use short strokes from one end of the blade to the other end. Do an initial scrape and repeat the process until you removed as much rust as possible. Wipe down the rust residue after each scraping.
4. Use a Thin Sandpaper
A thin sandpaper gives you more “feel” in your sanding than a thick sandpaper. Do light sanding first to check if you need to use a coarser sandpaper. Sand the rest of the  blade in a circular motion for optimum sanding. Repeat the process using a fresh sandpaper and always wipe off the rust residue after sanding. Clean both sides of the hand saw blade equally.
5. Use Paint Thinner
A paint thinner works best together with sandpaper. Pour small amount of paint thinner on a dry paper and scrub the entire blade lengthwise. Use the sandpaper after each application of paint thinner and always use a fresh set of sandpaper every time you apply more paint thinner. Do not forget to put on your  working gloves and mask before applying the paint thinner.
6. Use Paste Wax
A paste wax is used to protect your hand saw blade from further rust. Apply equally on both sides of the blade and wipe off the excess was with a clean piece of dry rag.  You can purchase a paste wax at your local hardware store.
7. Use a Coarser Sandpaper
To clean the back of the blade, use a coarser newspaper. Rip a small piece of sandpaper and with a block of wood or with only the pressure of your thumb, sand back and forth until you have removed all the rust, dirt and grime.
8. Wash Down with Paint Thinner
After all the scraping and sanding are done rinse down the entire blade with paint thinner and let it dry for at least four hours.
9. Use Mineral Spirits
You can also use mineral spirits as lubricant if you do not want to use a paint thinner. Apply an even and thin coating of mineral spirits on both sides of the blade using a clean, dry cloth and begin sanding. Repeat the process until you are satisfied with the results.
 forum activity
