About Decorative Wood Beams
When considering decorative wood beams there are a few things to keep in mind.
Synthetic or Real
There are many synthetic (faux) wood beams available. Some products are made of dense Styrofoam, or PVC plastic, others are made from recycled paper, or wood products. However, nothing beats the look of the real thing, wood! Check in your area for purveyors of architectural ornament, or demolition contractors. You might be able to buy remnant beams from other structures, and have them modified to suit your design plan. Or, if you like, construct new beams from scratch, either by box framing, or having the local lumber yard mill them from large stock.
Weight
Always consider the actual weight of the beams, and determine the method of attachment required to hold them in place, safely. Light synthetic beams require simple attachment, often into drywall alone. However, you will need to get solid attachment into the ceiling joists for the heaver wood, or box constructed beam.
Design Impact
When you design your room plan to incorporate beams, consider the impact the beams will have on the room lighting, as beams tend to cut off ambient light and create shadows. Also, keep in mind the color of the finished beam. Dark colors tend to create the feeling of a lower ceiling, where as light color tends create the feeling of more height to the room.
