About Epoxy Flooring
Epoxy flooring is one of the most popular types of garage flooring. It carries with it a few advantages and disadvantages for homeowners. Here are the basics of epoxy flooring and what you should expect if you install it.
Epoxy Flooring
This is an aggregate type of flooring that is made up of hardeners and resins. It is applied in liquid form and then it hardens on the floor. Once you put the epoxy on the floor, you will put vinyl chips or sand into the mixture to give it some texture.
Cost
There are many different types of epoxy flooring that you could potentially use. Because of this, there is a wide range of prices for epoxy flooring. If you are planning on getting epoxy flooring, you should plan paying as little as $.50 per square foot and as much as $5 per square foot.
Installation
The process of installing epoxy flooring is a very involved one, but you can complete it yourself. If you plan on installing this type of flooring by yourself, you will need help throughout the process. The most difficult part of the installation is going to be preparing the floor. You have to make sure that the concrete floor is completely clean and free of grease. Use a degreaser and a pressure washer to make sure that the concrete is completely clean. Otherwise, the epoxy might not stick to the floor and you will end up with big problems down the road. If there are any cracks in the concrete, you will want to make sure that you cover them up with self-leveling compound. You will then roll the epoxy mixture onto the floor with a roller. You will then spread vinyl chips or sand on top of the floor and let it dry overnight. At that point, you can sweep off the floor and continue to let it cure.
Pros
This type of flooring has a few different advantages. For one thing, it is known for its durability and protective abilities. If you drop something on the floor, you are not likely to damage the epoxy flooring. It does not easily scratch and it performs well in high-traffic areas. Because of its durability, many people put it in garages, but it can also be used inside the home as well. Many people also use it in commercial areas because it can stand up to a lot of wear and tear. Even though it can be difficult, most people can install this type of flooring by themselves. This allows you to save money on installation costs.
Cons
Even though they are durable, epoxy floors tend to lose their shine over an extended period of time. In many cases, they will also start to yellow after a few years. If you let your epoxy floor get into direct sunlight, it can damage the floor and the top layer will start to turn into a powder.
