cancel
Job type :
Zip Code :
community forums
comments
About Maple Lumber
Maple lumber is used in wide range of high-end products ranging from cabinetry to hardwood flooring. Their warm and natural tones are an ideal fit for both traditional and modern designs, which is why it’s commonly found in most homes across America.
Maple Carpentry
Maple lumber is used in the construction of high-end cabinetry due to its durable beauty. These cabinets can either be found in a natural or stained finish, depending on your preference. Maple flooring shares many of the same characteristics of maple cabinetry since the same grade of lumber is used in the production of both. The main difference between the two lies in their finish since maple flooring is subjected to much more abuse.
Maple Flooring
Maple wood flooring is also used in the construction of solid wood doors and mouldings as well. You can find these doors in a variety of designs to compliment any home. There is maple door casing, base moulding, and crown moulding to enhance your maple doors. These mouldings and doors can be finished with a clear coat or in various stain options.
The uses of maple lumber in cabinetry, flooring, and mouldings will continue to increase as their design benefits continue to gain popularity.
member comments
Did-it-myself Projects
updated by Sous-sol
did this on 9/22/2009
Building A Shed
updated by leftylew51
did this on 8/12/2008
Back Yard Paridise
updated by windgenerator
did this on 7/11/2008
Small Wind Generator
Your Winter Home Checklist
sponsored articles of the day
