Login Error
Close
About Pine Lumber
by DoItYourself Staff
There are many different species used in the production of lumber, each with its own advantages and disadvantages; pine lumber is one type of lumber that can be used in a number of applications.
Pine Lumber Used for Variety of Finishing Products
Pine lumber is a softer wood that is used in a variety of finish products such as cabinetry, flooring and mouldings. Their natural grain and knot patterns make for a beautiful design which is why they were commonly used for wide-plank wood flooring. Pine lumber is also commonly used in all types of moulding, including base moulding, window and door casing, and crown mouldings. These mouldings can either be stained or painted, depending on the homeowner’s preference.
Pay Attention to the Grade of the Pine Lumber
There are different grades of pine lumber available to use depending on the type of project you're undertaking. You can differentiate between the grades by the number and name associated with the wood. For example, No. 2 pine will have more knots and imperfections than select white pine, which will have virtually no perfections. No. 2 pine lumber would be the ideal choice for a country kitchen shelving project while clear white pine is the ideal choice for window extension jambs and mouldings.
The availability of pine lumber will ensure that this product is a regular staple in most homes across the nation.
 forum activity
