Above Ground Salt Water Pools vs Underground Salt Water Pools
Salt water pools offer a healthier and better alternative to heavily chlorinated fresh water pools. Salt water pools minimize hair damage, eye burns and dry skin when compared to the latter. These pools do not completely get rid of using chlorine to sanitize the water; instead, they use chlorine generated from salt. This allows pool owners to produce just enough chlorine to sanitize the water without buying expensive chlorine from a store. In addition, salt water pools provide a more comfortable experience for swimmers.
Before deciding to install a salt water pool on your yard, determine if you want it to be above ground or in-ground or underground. To help you decide which one to choose, here are some basic things you might want to know.
Building Cost
Above ground salt water pools cost ten times less than underground types. Underground or in-ground pools require a hole to be dug out of the yard before the pool can be built. The digging process adds more cost to the whole project. For smaller budgets, it is best to go for above ground types. However, for people who are willing to spend more cash on a pool, the underground type will work just fine.
Permanency
A lot of people who want to have pools in their yards do not own their homes. In such cases, a temporary above ground salt water pool will be the best option. For people who own their own homes, an underground pool can be a good option if they want to have a permanent pool built in their own yards.
Taxes
In most areas, underground pools are taxed. This adds more expenses to the owner of the pool. However, the taxes imposed on underground pools do not extend to above ground pools. For people who wish to own a pool but do not wish to add more financial obligation to their already steep taxes, an above ground pool is best to choose.
Home Value
Underground pools are a no-no to people who want to sell their homes in the future as it may lower the total value of their homes. Homes with underground pools are less targeted by real estate investors or people who want to buy a home. Remember that not all people want to have a pool in their yards. In case you really want to have a pool, but want to sell your home in the future, it is best to invest in an above ground salt water pool rather than an underground one.
Water Heating Process
During hot summer days, water on above ground salt water pools heat much faster than in underground ones. While the sun may provide a natural heating process during hot summer days, the heat is not readily absorbed by the water in underground pools because the ground provides a cooling effect.
Overall, above ground salt water pools have more advantages as compared to underground salt water pools. Before deciding to have either one built in your yard, weight the pros and cons of each type of pool and decide which best works for you.
