ADA Handicap Bathroom Regulations
Installing or renovating a handicap bathroom requires proper planning. Persons with disabilities have unique needs that must be considered when constructing bathrooms designed for their use. Below are some of the most important aspects that you must pay attention to if you want your bathroom to meet the requirements specified under the Americans with Disabilities Act (ADA).
1. Floor Space
When constructing a new bathroom for a handicapped person, you need to provide for an unobstructed floor space measuring no less than 30 by 48 inches. This clearance will allow a wheelchair to be brought inside the bathroom while still ensuring enough room for a person’s legs and feet. If you are just remodeling, you can choose to have a T-shaped bathroom with an aisle measuring at least 36 inches. This much space is enough to allow a wheelchair to turnabout via a three-point turn. Ramps are also needed if the handicap bathroom is built higher than the ground level.
2. Toilet Stall
The toilet stall should have a width of at least 60 inches. Moreover, the toilet seat in the handicap bathroom should be installed with a height between 17 and 19 inches above the floor. Make sure that the flush handle or lever is placed on the most accessible side of the toilet seat. Remove or avoid installing furniture and fixtures in the toilet stall to prevent unnecessary obstructions.
3. Bathroom Door
Install a swing-out door that will be wide enough to accommodate a wheelchair or other handicap assistance devices. If the designated bathroom entrance does not have enough space, you can install a swing-away door using special expandable hinges. This type of door can add more clearance to the door opening without eating more floor space.
4. Grab Bars or Handrails
Grab bars or hand rails are very vital to persons with disabilities. These devices allow a handicapped person to easily and safely transfer from the wheelchair to the toilet seat and back again. Under the ADA, the grab bars must be smooth, easy to grip, and have a diameter of at least 1 1/4 to 1 1/2 inches. Always make sure that the bars are securely mounted to the bathroom or toilet stall wall. It is recommended that safety bars and rails are installed at a height between 34 and 38 inches above the floor. Remember, the bars must not take up the free space required under the ADA guideline. In fact, an additional clearance of 1 1/2 inches is required to reduce the chances of injuries in case a person slips.
5. Bathroom Accessories
If a urinal for the handicapped is installed, its rim should not be higher than 17 inches from the floor. For more convenience, an unobstructed space of at least 30 by 48 inches should also be available in front of the urinal. The ADA has also issued regulations as to the installation of a lavatory in a handicap bathroom. The wash area or lavatory should have a clearance space of 29 inches from the floor. The maximum height of the countertop should not exceed 34 inches. Again, an unobstructed area measuring 30 by 48 inches must be available in front of the lavatory. Lastly, all bathroom fixtures should be easy to operate
