Login Error
Close
Add a Kitchen to Your Basement
by DoItYourself Staff
There are many uses to which a basement can be put. Some of these include using it as a laundry room, a workout room, a home theater or family room. If you are using your basement as the family room, you might want to add a kitchen to it to make life all that much easier for everyone in the family. However, adding a kitchen to the basement is not the same as adding a kitchen to the ground floor of a house. You need to keep a few more points in mind.
Ventilation
The first thing you need to keep in mind is ventilation. You need to install an electric chimney that will work efficiently and quickly to get rid of any cooking smells fast, unless you want a family room that smells of food. As food smells can linger a ventilator is very essential in a basement kitchen.
Fire Safety
Again take additional precautions to ensure that small fires can be put out at once. The exit to the basement should also be away from the kitchen so that small children and others can make a quick getaway. Have a fire extinguisher handy as most home fires start small and in the kitchen.
Floors
Basement floors are normally made from concrete. So they will be strong and sturdy enough to carry the weight of washing machines, refrigerator and dishwashers. As the basement is isolated from the main floor of the house, you can set the washing machine and dishwasher at full speed without having to worry about the noise disturbing others. This is a great advantage with basement kitchens.
Furnishings
You can use the old furnishings and cabinets from your main floor kitchen to furnish this space. This way you will save both money and the environment. Add colorful rugs on the floors and paintings on the walls to enliven the family space and kitchen.
Drains
The basement is close to the drains of your house. So adding a kitchen sink and connecting the washing appliances is a breeze. You will not have to spend a fortune to install pipes to the basement.
Flooding
As basements are prone to flooding and all your expensive gadgets will be in one place in the basement make sure that you waterproof your basement thoroughly before you install a kitchen in it. Otherwise, you stand to lose thousands of dollars if your basement gets flooded. Also get an insurance policy against kitchen flooding if you do not have one already.
Wiring
Like drains, the wires, too, will be easy to install as the mains are probably in the basement. Just ensure that you install the correct plug points for each of your heavy-duty gadgets and appliances.
By taking these precautions and steps you can easily convert a small area of your basement into a kitchen. This way you can enjoy great family times together and also entertain friends in the basement.
Just imagine the alternative—having the kitchen one floor above the entertainment or family room. You will forever be trudging up and down with food, drinks, and other refreshments from your kitchen to the family room. It makes more practical sense to have your kitchen next to the family room. This way you too can take part in the family activities even as you cook and wash up. If you have young children, you can keep an eye on them and entertain them even as you cook the family meal or bake treats. The possibilities of use are endless with a basement kitchen.
 forum activity
