If you are looking for a way to give your kitchen a charming, country-style feel, adding a distressed finish to your cabinets is a great way to go.
Tools and Materials You'll Need:
- Power drill or screwdriver
- Thick chain (optional)
- Sandpaper, medium grade
- Lint-free cloth
- 2 inch flat brush
- Water-based glaze
- Water-based polyurethane
Step 1 - Prepare the Doors
Clean cabinets thoroughly. Remove hardware on all the doors, then remove the doors from the cabinet frame. If you would like a heavily distressed finish, beat the wood with a thick chain to create indentations. Sand the entire door with a medium, 60 CAMI, sandpaper. Wipe off excess dust.
Step 2 - Apply Paint
Apply an even coat of primer, then allow to dry. Brush on a coat of paint, typically in a cream or white shade. If necessary, apply a second coat until the cabinets are completely covered. Let dry thoroughly.
Step 3 - Distress the Doors
Sand the edges and corners until the primer or wood shows through (depending on how much you sand off). Wipe off the dust before brushing on a dark, water-based glaze in long, even strokes. Before the glaze dries, use a rag to remove as much as desired, following the same up-and-down direction the glaze was applied.
Allow the glaze to dry thoroughly before applying a water-based, satin-finish polyurethane to protect the cabinets from damage. When the polyurethane has completely dried, reinstall the doors before adding the hardware.
Questions of a Do It Yourself nature should be submitted to our
