Adding A Ridge Vent To Your Roof
A ridge vent is regarded central to basic roof ventilation installations. Roof ridge vents are needed for ensuring that the circulation of fresh air is maintained within a construction. The presence of ridge vents is useful for extending the durability of roofing materials, attic installations and elevated rafters that tend to be damaged by the internal heat. Adding a ridge vent may seem daunting to many people but with some basic guidelines and useful tips, ridge vents can be installed without any concerns.
Things Needed For Adding Ridge Vents
- New ridge vent
- 1½-inch roofing nails
- Shingles
- 2-inch chisel
- Standard tape measure
- Utility knife or Hook knife
- Flat bar and Pry bar
- Chalk line
- Claw Hammer
- Circular saw (preferably with a carbide blade)
- Extension ladder for reaching the roof
12 Steps to Installing a Ridge Vent
- Peel away the shingles from ridge cap of the roof with the flat bar. Some shingles should be saved for later use.
- If the ridge is ending at a chimney or a wall, it is advised to leave about 10 inches of shingles.
- With the chalk line, make a 7/8-inch long line, extending downwards from the ridge board.
- Use the tape measure to set the saw’s depth.
- Cut the roof sheeting, using the circular saw and saw until the edge of the roof-sheeting boards is visible.
- Use the utility or the hook knife to remove the shingles and tarpaper.
- Along the chalk line, saw away both sides of the roof peak.
- Use the chisel to sever the wood that hangs from the saw-cut edges.
- Use the pry bar to remove the sheeting that has been sawed.
- Place the new ridge vents in the space created due to the removed sheet.
- Use roofing nails to secure the new ridge vent.
- Using roofing nails, start to cover the roof vent with the saved shingles. If necessary, use new shingles.
