Adding Windows To An Attic
what you'll need
- Framing boards
- Window
- A level
- A hammer
- Nails
Installing an attic window during an attic finishing project a great enhancement that will increase the value of the space. Often, new home construction today includes a “bonus” or attic room ready to be completed. Older homes usually have unfinished attic space that can be “dormered” providing window areas to light the attic room.
Before you attempt this type of remodeling project, get a good understanding about what this project entails and how you can be successful.
Step 1: Examine Work Area
Examine the surface area of your attic room determining where to locate the window. The amount of usable space will dictate how many windows can be installed and where these will go.
Step 2: Choosing a Window
Decide what type window(s) you want to install in your attic room. There are an incredible amount of choices for style and size. Make sure you take careful measurements of your attic room wall space so you can determine the exact size window you can install in your attic room.
One of the most important steps when planning this project is the selection of a window type. Available space in your attic room will dictate size and number, but you still need to choose a style and a type. The process may seem overwhelming, however, with Internet access you can investigate all the varieties of windows available and possibly make a purchase online which can lead to additional savings. Many websites will not only sell you the window but will also provide a tremendous amount of information about the different types of windows that will help you make an informed choice.
Step 3: Prepare the Wall Area
If sheetrock is present, remove it revealing the empty wall area to mark off the space where the window will be placed. Make sure that adequate structural support will remain after window installation. If you need some consultation, contact a professional to answer whatever questions or concerns you have.
Step 4: Stud Removal
Remove any non-load bearing wall studs in your marked window area preparing an open spot where the window will be installed.
Step 5: Window Frame
Using correct measurements, cut a window opening and prepare a frame with properly cut boards. Keep in mind to place headers at the top of the window opening for extra support. Place all boards around the opening, securing with nails.
Step 6: Install the Window
Place the window you have selected into the installed frame, attaching it securely. Make sure to use shims placed in between the frame and the window to level it off. Make sure the window is squared off checking it with a level. Do not begin nailing the window to the frame until you are certain the window is level. Once satisfied, nail the window to the frame and then add sealer and insulation around all sides.
