cancel
Job type :
Zip Code :
community forums
comments
Adhesive
Adhesive or glue is a compound that binds two items together, you can find adhesive in natural or synthetic forms. The modern adhesives that are found on today’s market are very strong and they are an important part of the construction industry.
The Different Types of Adhesive
Natural adhesive is made from biological sources or inorganic minerals such as animal skin, natural resins, or vegetable matter. A natural adhesive is sometimes referred to as a bio-adhesive. A good example of a natural adhesive is the combination of flour and water to create paste.
Synthetic adhesives are thermosetting or thermoplastic elastomers.
Drying adhesive products are normally a mixture on ingredients such as polymers that are dissolved in a solvent. Examples of drying adhesives are white glue and rubber cements. As the solvent evaporates the adhesive will harden. These can be found for many different types of products, such as wood, metal, plastic, or paper.
There are several other adhesives you can find on the market
• Contact Adhesive
• Hot Adhesive
• Reactive Adhesives
• UV and Light Curing Adhesives
• Pressure Sensitive Adhesive
Depending on the job that needs to be done, there is an adhesive made especially for it.
More Reading
DoItYourself.com System Error
We're sorry, it seems there is a problem getting you the web page you are looking for.
If you would like, you can email admin@doityourself.com and report the problem, or try refreshing the page.
Sorry for the inconvenience.
Error Message - You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ') AND published=1 AND deleted=0 order by rand() ASC limit 3' at line 1
Error Number - 256
File - SmoothyMysql.class.php
Line # - 118
