Adjusting Kitchen Lighting
Kitchen lighting is often ignored when designing kitchen space. Lighting fixtures in the kitchen are chosen usually from a budgetary perspective, but, choosing appropriate lighting fixtures is mandatory for visually appealing and comprehensively functional rooms. Those who are redesigning their kitchens can use a blended redesign approach; combining new installations along with adjusting the present kitchen lighting fixtures.
Understanding Kitchen Recessed Lighting — recessed lighting is also known as pot light, downlight and can-light. The two basic components of recessed kitchen light are a frame and the reflector. Recessed kitchen lighting has a typical configuration where lighting fixtures are installed into an opening in the ceiling by manipulating hollow spaces. Depending upon the ceiling and joist construction, the reflector and the recessed trims are chosen.
Understanding Layered Lighting Effect — you should avoid using a single, extremely-bright fixture to light the entire kitchen. A well-designed kitchen should have layers of lighting elements, blending different types of light. Using different lighting sources, with varying illumination capabilities, and separate controls, is highly recommended. If you are redesigning your kitchen, try to incorporate:
- Task Lighting Fixtures — they are the principal source of illumination in the kitchen. Task lighting is installed along the countertops, slabs and spaces meant for preparing meals. Task lighting fixtures are installed slightly lower than conventional kitchen lights, along the upper edge of kitchen cabinets.
- Ambient Lighting Fixtures — these are used for making the kitchen space appear cozier. They are popular for creating a typical warm glow that helps to soften the shadows. If your kitchen has cabinets that fall short of the ceiling by about 3 feet, this space is perfect for installing ambient lighting fixtures.
- Indirect Lighting Sources — for creating a more dramatic look, you can blend indirect light with direct lighting fixtures. Indirect lighting is often used for adding elegance to the kitchen space. It is created by hiding the source of light from the main view. For this, lighting fixtures can be installed under the wall cabinets or in a layered format, along the ceiling areas.
Adding Overhead Kitchen Lights — this is a simple way of pumping-up the decorative appeal of the kitchen. Overhead lights are commonly installed over busy working zones in the kitchen. The most common overhead kitchen lighting fixtures are the task lights used over kitchen countertops. You can use the roof of the kitchen for hanging classic fixtures like small chandeliers or Victorian recessed lights. If a particular kitchen spot continues to remain shaded, you can hang lighting fixtures over it, using a designer chain or a pendant.
Adding Under-cabinet Kitchen Lighting — this is the easiest form of kitchen lighting to procure because it is readily available at most lighting stores. If you are struggling with the limited capability of fluorescent lighting under the cabinets, halogen fixtures can be used. They are highly-recommended for under-cabinet lighting needs, as they cast a bright, white light. The idea should be to keep under-cabinet lighting expenditure to the minimum. Under-cabinet fixtures should ideally be hard-wired. This ensures that no wires are visible and the nearby receptacle slots do not remain permanently occupied.
