Login Error
Close
Advangates of Slate Flooring
by DoItYourself Staff
Slate flooring has the ability to create an interesting hewn pattern, with a rough appearance on the floor. It is made of a natural durable material, that creates an exquisite design for the floor. It does not require much maintenance. There are many advantages of slate flooring, which most homeowners are simply not aware of. Other than using slate as flooring, it can also be used for roofing.
Easy Maintenance
Slate flooring does not require much maintenance, but you may not realize that it can trap a lot of dirt, because of its natural stone. Don't worry, as it is very easy to keep it clean. Simply use a broom to sweep well. Then, mop the floor with a mild detergent, and you are done. To prevent scratches on your slate flooring, keep objects that have sharp edges, such as metal chair legs, and other metal items, away. With proper care, it can last you a lifetime.
Natural Material
Slate flooring is made of natural stone material. It is resistant to both allergen and bacteria. It comes in many natural colors for you to choose from. You do not need to apply heavy waxes on the floor, as it looks awesome and beautiful naturally.
Ideal for Homes
Slate flooring is durable, long lasting and hard. It is resistant to water. It is ideal for basements, entryways, kitchens and bathrooms.
 forum activity
