Login Error
Close
Advantages and Disadvantages of a Keyless Door Lock
by DoItYourself Staff
Keyless door locks have become very popular amongst homeowners in recent years. Although these locks were originally developed for use in cars with remote entry systems, they have been successfully modified for use in homes as well. There are a number of reasons to consider including a keyless door lock in your home. However, there are also some risks associated with the keyless system, so it's important to consider all pros and cons before you install a keyless entry system for your home.
Advantages of Keyless Door Locks
One of the main advantages of a keyless door lock is the fact that you will not be required to carry a key. This makes it less likely that you'll lose the key and have a difficult time getting in to the home. It also means that you won't need to store a spare key somewhere on your property, as many home owners currently do. This poses a security risk, so eliminating the need for that additional key helps to make your home safer.
Another advantage of a keyless door lock is the fact that you can provide entry into your home to others at your discretion. You will not need to make copies of a key or leave keys for someone else to get in to your home. Rather, you'll simply need to tell those people the proper code to put into the keyless entry system in order to gain access. With the system in place, you can also tell exactly when and how people attempted to access your home. This gives you a good idea of how secure your house is.
Disadvantages of Keyless Door Locks
While there are many benefits to including a keyless door lock system in your home, there are also some major drawbacks to consider as well. The first of these is a security issue. While keyless door lock systems are generally very safe and are designed to alert police or other authorities if incorrect codes are entered too many times, it is nonetheless possible that an intruder may be able to gain access to your home through this system by guessing or hacking the code.
Just as you can forget your keys and be locked out of your home, you can also forget the pass code to access your keyless entry system and be locked out as well. This can pose a problem if you have a difficult time remembering things; it's safest to use a completely random code and to avoid things like birth dates.
One final disadvantage of keyless door locks is that those systems which are powered by electricity may not function properly in the case of a power failure. This can leave your door completely locked throughout the failure, or it may result in the door not locking properly and remaining open during the failure as well. Most systems have battery backup systems in this case, however.
 forum activity
