cancel
Job type :
Zip Code :
community forums
comments
Advantages for a Lighted Digital Deadbolt Lock
A lighted digital deadbolt lock may increase the security of your home. Read on to learn about the advantages of using this type of lock on your exterior doors.
1Made with Strong Materials
Most digital deadbolts are made of metal, both internally and externally, which increases their security strength. Additionally, many keypad covers, battery compartments and open/close buttons are also constructed of metal.
2They Can Take a Beating
Many of these locks are built to survive hammering. Some units have as much as a 2.5-mm thick metal mounting plate, which keeps the circuitry safe. Therefore, intruders can not simply smash their way into the lock.
3 – Exterior Mounting Plate Blocks
Some locks are made with exterior mounting plate blocks, which prevent access to the deadbolt latch -- if for any reason the exterior unit is dislodged from the lock. This means your home is still safe, even if the lock is broken or harmed in any way.
4 – Strong Throwbolts
Locks are oftentimes constructed with 1-inch throwbolts, which are many times made stronger with a 5-mm. thick carbon rod. This feature renders it impossible for somebody to saw through the lock.
5 – Small Openings
In many cases, the openings between the exterior and interior units are extremely small and covered in such a way that cold air cannot get into your house through it. This feature also helps prevent rust and condensation. Also, models with built-in weep holes force moisture from the outer unit to drain down and out of the lock. In some instances, these weep holes are partly blocked by the mounding plate to help fend off break-ins.
6 – Batteries are Kept Secure
The lock’s battery compartment cover is often connected with a screw to keep batteries from falling out. In some instances, there are rubber pads that firmly keep batteries where they belong.
7 – Manual Override
If your lock comes with a manual override, this feature directly operates the deadbolt latch so you always have the option to open your door from the inside.
8 – Protected Vital Parts
In many cases, the essential components of the lock—including CPU, PCB, batteries, motor, deadbolt latch, drive mechanism—are situated inside the lock and on the inside side of the door, which helps keep intruders from accessing vital parts.
9 – Bypass Circuitry
Locks equipped with bypass circuitry keep the PCB protected in the possible instance of a high-voltage attack so that—if this happens—the lock will remain securely locked.
Many home intruders are crafty when it comes to breaking into homes, which means having a digital deadbolt lock is one way of staying many steps ahead of these criminals. Each of these advantages contributes an extra degree of home security.
member comments
Did-it-myself Projects
updated by gibburnz
did this on 11/23/2009
Small Kitchen Rental Upgrade
updated by Rocky1008
did this on 11/07/2009
Garage Shop Organizing
updated by dhammon
did this on 11/04/2009
The Deck
Painting Stylish Wall Borders
sponsored articles of the day
