Efficiency
Adding a fireplace insert can actually increase the efficiency of your fireplace. Since an insert is like adding another fire to your fire, the big fire won’t have to draw as much heat to aid in combustion. This means your room will stay warmer for a longer period.
Clean
A fireplace insert is completely clean. It doesn’t waste energy, and it doesn’t add any toxins in to the air.
Never Be Without Heat
Even if the power is out, you’ll be able to use the insert to generate heat.
Cost
While the upfront cost may scare some people away, it’s important to remember the savings over time. A standard fireplace is a pretty inefficient appliance. They are great to look at, and they will heat a room. But you loose a lot of heat. Adding an insert helps combat heat loss. An insert can potentially save you thousands over the course of a few years.
Questions of a Do It Yourself nature should be submitted to our
