cancel
Job type :
Zip Code :
community forums
comments
Advantages of an Electric Fireplace
An electric fireplace adds both functionality and beauty to a home. They add heat to the home, while at the same time adding to the ambience. There are other advantages as well.
Easy to Install
When you compare the installation of an electric fireplace to a standard fireplace install, you’ll see it’s much easier. In some cases, depending on the style you choose, the fireplace can easily be moved from one room to another.
Environmentally Friendly
When you compare the usage of an electric fireplace to one that burns wood, you’ll find that the electric fireplace is more environmentally friendly in that they do not add smoke or fumes to the environment nor do they add carbon dioxide to the air that we breathe.
Convenience
Electric fireplaces are much more convenient than those that burn wood. Imagine coming home and wanting to relax in front of the fire. With a wood fireplace, you have to get the fire going first. That’s not so easy to accomplish, but when you have an electric fireplace installed, you’ve got an instant "fire” and the heat to go along with it at the flip of the switch, or from the remote if you choose one of the styles that comes with a remote control unit.
Versatility
Imagine a fire without the heat, the ability to change the style of the flame at will by changing the color and flame speed. That’s what you get with an electric fireplace. You get all the versatility that you need and you can enjoy the relaxing flames without the heat if that is your wish. The modern design of these fireplaces give you the option of almost setting you want on some models, and the heat if you want it, is an added bonus!
Design and Style
Electric fireplaces come in all shapes, sizes and styles. You can get those that will hang on the wall, and others will set on the floor, complete with the traditional mantel. The floor units are even more versatile because they are quite literally portable, and can be moved from one room to another with relative ease.
Safety
Electric fireplaces do not create a real fire. For this reason there is no worry of cleaning, nor do you have to concern yourself with hiring a chimney sweep to clean the chimney. There’s also no danger of carbon monoxide from the unit for this reason.
You also do not have to worry about putting out the fire before leaving the room or going to bed; simply flip the switch or push the button on the remote control and it is out! There are many other advantages too. Each different type of unit will have its own advantages and those should be considered before you decide which you want to purchase.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
Painting Stylish Wall Borders
sponsored articles of the day
