Login Error
Close
Advantages of Choosing an Iron Trellis
by DoItYourself Staff
If you are considering landscaping your garden with a trellis, then there are a number of reasons why you might choose an iron trellis for the job. There are so many different types of trellises that it can be difficult to choose between them, but the iron trellis has a long tradition of being used in gardens, and there are many makers of the iron trellis. These kinds of trellises can add a great deal to the appearance of your garden, and you should be able to find a pattern which not only looks pleasing to the eye but suits the style and design of your home and land.
Design Options
If you are looking for the perfect trellis design, then the first place you should search is among the iron trellises. Iron is a traditional garden metal and they have been created with a number of interesting designs and plans. There are options from the straight forward rows of lines to more complicated floral and deco patterns that show off the elegance of the garden beyond. As accessories to flower beds or simply as markers for the garden, the iron trellis is one of the most well-designed trellises available.
In addition to standard designs, you can also choose to have your iron trellis custom made and then adapted to any design you choose. If you are looking to have a particular design for your garden, for example a knot-garden landscape, then you can have the metal manipulated to suit your needs. Iron trellises fit with traditional gardens and compliment them better than plastic or wooden trellises.
A Variety of Uses
The iron trellis is adaptable to a number of different situations. In the Victorian era, the trellis was used outside homes and often separated the main doorway from basement steps, dividing the homeowners from servants. These trellises were tall, often up to waist height, and usually took a coat of paint every year to keep them durable. More modern iron trellis designs allow the user to have a small iron trellis which can be used to mark the edge of flower or vegetable beds, or to be combined in stacks to support a plant such as ivy. Modern trellises can be adapted for a wide range of uses. In addition, as the iron trellis is light and malleable, you can move it around the garden as you choose.
High Durability
One of the biggest advantages that comes with buying and using an iron trellis is the durability of the metal. Unlike wooden or vinyl trellis designs, you can install iron trellises in your home and they will last you a lifetime. The paint on an iron trellis is more likely to wear out than the metal itself, and you can easily fix that by repainting with a suitable metal paint. Unlike wood or plastic, the iron trellis will withstand most weather, and can be left outdoors even during frost and snow.
 forum activity
