Login Error
Close
Advantages of Cultured Marble Countertops
by DoItYourself Staff
Cultured marble countertops are a popular choice for bathroom and kitchen counters. This type of counter is a solid surface that is made out of a cast polymer. Read on to learn some of the advantages of using cultured marble countertops.
Price
One of the biggest advantages of cultured marble countertops is that it is very affordable. Cultured marble is one of the least expensive countertop options that you will find. By purchasing this type of countertop, you can get your remodeling projects done for a fraction of the price of using other materials. You can usually secure culture marble for half or a third of the price of natural stones like granite or quartz.
Solid Surface
Another advantage of cultured marble is that it is a solid surface. Many people opt for tile on their countertops, which can cause several functional problems. When you use tile on a countertop, you have to worry about the grout joints. When preparing food on your counter, the food can get down in the joints. Tile counters are typically harder to clean than solid surfaces because you have to regularly maintain the joints.
Another issue with tile counters is that the grout can stain or it can come out of the joints. With solid surface countertops, you never have to worry about these problems. A slab of cultured marble is customized for each unique project. Providers will come get a detailed measurement at your house and then will fabricate the counter to the specific size that you need.
Look
Another advantage of cultured marble countertops is that they look great. Many people love the clean and simple look that cultured marble provides. It does not have a lot of grain or design in it, which means its has a very classic and timeless look. Even though it is not very expensive, it creates a high-end look that you will find in many nicer homes.
Easy to Clean
Another advantage of cultured marble countertops is that they are easy to clean. You can wipe them down with most household cleaners without fear of damaging them. Regular stone, on the other hand, are often very porous. When you clean these stones, you have to be careful with what cleaners you choose because some chemicals can permanently etch the surface. With cultured marble, you do not really have to worry about these issues. You can simply wipe down the counter with a regular surface cleaner. The surface is also so smooth that it wipes down very easily.
Durable
A cultured marble counter is also very durable and can stand up to a lot of wear and tear. You do not have to worry about the counter chipping easily like you would with some of the natural stone products. While it can be damaged, it is not as susceptible to damage as some other popular countertop materials.
 forum activity
