Advantages of Recessed Lighting in Your Drop Ceiling
Aside from being an extremely practical lighting choice, recessed lighting can dramatically improve the aesthetic qualities of any room. One of the primary benefits of recessed lighting is the space that will be saved by installing these lights. Since recessed wall lights are embedded in the ceiling, both the visual and physical space is minimal.
Alternative Lighting Choices
One of the most popular alternative lighting choices that is seen in rooms with drop ceilings are elongated, hanging fluorescent lighting fixtures. Aside from being visually unattractive, these lighting fixtures are normally suspended anywhere from 1 to 4 feet from the ceiling itself. This space can be visually unappealing and make a room look smaller. In comparison, since recessed lights are installed directly into the ceiling, there is a good amount of space saved when they are incorporated, which in turn leads to the appearance of a larger, more open space.
Weight
One of the nicest things about recessed lighting is the lightweight nature of the completed units. Recessed wall and ceiling lights are light enough that they do not have to be secured directly to ceiling joists or wall studs, they virtually “float” in recessed spaces with very little supporting them besides the housing canister, baffle and trim contained within the lighting kit.
Since drop ceilings are often made up of little more than flimsy metal supports and thin, lightweight panels, recessed lighting can be an excellent lighting choice where many other types of lighting fixtures are not practical. The vast majority of alternative lighting fixtures are simply too heavy to be supported by drop ceilings, and are therefore impossible to install. With recessed lighting, these problems will not be an issue.
Aesthetics
As with any room that requires additional accent or ambient lighting, recessed lighting in a drop ceiling can dramatically improve the look and feel of any room. Recessed lighting is both sleek and modern, turning a potentially drab, uninspired room into a visually interesting space.
Finally, recessed lighting is very versatile in terms of what can be done with the lights themselves. Individual recessed lights can be adjusted to provide either pleasant ambient lighting or accent or spot lighting as circumstances require. These are benefits that cannot be duplicated by other types of lighting fixtures.
Special Options
Recessed lights also provide dimming effects that are easy to control. You can install these lights in a media room and dim the lights to view movies. Or, you can install the lights in a bedroom, kitchen or bath to provide a large amount of light into a room. Either way, these lights are versatile and highly coveted for many homeowners.
The most important benefit of recessed lighting is also the cost, they are very affordable. The money required to install these lights is not much more than other types of lighting sources.
