Login Error
Close
Advantages of Using Butt Joints
by DoItYourself Staff
A butt joint represents the most basic and simplest joinery technique that is adopted to connect two wood pieces in a woodworking project. In other words, butt joints are formed when two wood pieces are welded and simply fixed and fastened face to face. Even though it is not the strongest of joinery techniques, the butt joint is considered effective for certain projects, especially for house framing works and making simple boxes. Read on to learn about some of the key advantages of using butt joints.
Simplicity
Perhaps the most significant feature of the butt joint is that it is easy to set up and weld. All you need to build a strong butt joint is two flat pieces of wood or metal, friction clamps and an angle grinder. Top quality glue can add to the strength and durability of butt joints.
Durability
Butt joints provide decent durability. However, their strength is largely based on the expanse of the surface area that has been joined. In fact, the more area is joined, the better will be the strength of the joint.
Uniformity
Above all, the prime benefit of using butt joints is that they are extremely helpful in projects that require uniform appearance.
 forum activity
