Login Error
Close
Advantages of Using Round Soffit Vents
by DoItYourself Staff
Ventilation is important when thinking about smaller spaces, using round soffit vents to do this will bring you many benefits. Knowing how soffit vents work, and the advantages of installing soffit vents will make all the difference in your decision.
How They Work
Soffit vents draw cool air into the area, while hot air is pushed out through other vents.
Saving You Money All Season Long
Soffit vents allow cold air in, so the amount of cold air dispersed throughout your home is lowered, which in turn lowers your energy costs. The same principle applies in the winter as well.
Round or Square
Square or round soffit vents are both a good choice, but you have to decide which one to go with. Round soffit vents are most times easier to drill through. Depending on how you want it to look, and how you want to actually go about installing the vents is when you will discover which vent you will want to go with.
Seeing the Benefits
After installing these soffit vents you will see what a difference they actually make. Make a decision in which vent you want to go with keeping in mind the above information, and start from there. You will love the difference it makes in the area's you install them, and in the energy you save.
 forum activity
