Login Error
Close
Advantages to Making Your Own Organic Gardening Products
by DoItYourself Staff
Organic gardening products are certainly the way to go when you are trying to live green. Using organic gardening products not only saves you money but gives back to the environment. You can buy organic gardening products from local gardening centers and that is a way to get started. You can also make your own organic gardening products. This article will provide you with some of the things you can make and their advantages to you.
Saving Money
What you need to make organic gardening products is all around you. They can be things that you grow and normally would discard or things that you use on a daily basis from food to waste containers. Instead of purchasing things to aid you in your gardening you can save hundreds of dollars each season creating your own organic gardening products.
Giving Back to the Environment
In order to stay ahead of the times we often forget about the Earth and it gives to us so that we can drive our cars and live in nice houses. The continuation of construction takes away from the environment that we also need to survive. Using organic gardening products means you are not relying on the corporations to provide them for you. For those products that you do use that are manmade you are returning them to the environment by allowing them to decompose. Doing this helps to replenish natural resources and to complete the circle of life that is so important.
Disposable Potting Planter
One of the organic gardening products you will see being used a lot these days is a disposable potting planter. This does not refer to using them and throwing them away but to how they disintegrate and decompose in the ground. Many of these planters are infused with plant food and the like. You can make this yourself out of old newspapers. Simply transplant the root ball to the center of several sheets and bring the sides up. Tie a piece of twine around the paper to secure it and plant it just like this. Add plant food to the paper if you like. The result will be the same.
Home Composting
Composting is what is done to make your own fertilizer. The materials and the process are all very simple. A recycled drum on a barbecue or rotisserie spit is the main tool to use. You will place inside layers of old newsprint and some soil. Wet the paper down until it is moist. To this you will add worms and green vegetables like lettuce and spinach. You can use fruits and other vegetables too. Basically, anything you would throw away that is organic can be placed in the drum. Every other day you turn the drum. The worms eat and dispose of everything and within a week you will have a fertilizer that is better than anything in the store.
 forum activity
